[Geomoose-users] Wms layer showing pinkish tiles.
Moore, Richard J richard.moore at mnsu.edu
Wed Dec 16 13:08:19 EST 2009
Franz,
Try the following .map file for the map file and the subsequent lines of code for the map source and catalog.  This serves it through the mapserver wms service
Rick
# For those WMS layers that only supports geographic projection (e.g. epsg:4326)
# You can still use them by having MapServer reproject them on the fly.
# You then have the option to serve it via MapServer's WMS service or
# call it as a normal MapServer layer.
# This example cascades the OnEarth (JPL) MODIS and Landsat layers through the
# local MapServer service.
MAP
  NAME 'nasa'
  SIZE 800 650
  STATUS ON
  UNITS METERS
  IMAGETYPE JPEG
  TRANSPARENT TRUE
	INCLUDE "../../geomoose_globals.map"
	WEB
		INCLUDE "../../temp_directory.map"
	END
  PROJECTION
    'init=epsg:26915' # I believe change this your projection of your mapbook projection parameter.  The 4326 is what the global mosaic is projected in.
  END
  LAYER
    NAME         nasa
    TYPE         RASTER
    OFFSITE      0 0 0
    STATUS       OFF
    CONNECTIONTYPE WMS
    CONNECTION "http://onearth.jpl.nasa.gov/wms.cgi?"
    METADATA
      "wms_srs" "EPSG:4326"
      "wms_name" "global_mosaic"
      "wms_server_version" "1.1.1"
      "wms_format" "image/jpeg"
      "wms_style" ""
    END #metadata
    PROJECTION
      "init=epsg:4326"
    END #projection
  END # layer
END #map
Line of code in the map-source area.  Create the above code as a nasa.map file
	<map-source name="nasawms" type="mapserver">
		<file>./data/wms/nasa.map</file> #change this per your location of the .map file
		<layer name="all"/>
	</map-source>
Line in the Catalog area---
	<layer title="NASA Globe" src="nasawms/all" status="off"/>
-----Original Message-----
From: Nils Zierath | Center for Development Research Bonn (ZEF) [mailto:nils.zierath at uni-bonn.de]
Sent: Wednesday, December 16, 2009 4:30 AM
To: FRANZ OKYERE
Cc: geomoose-users at lists.sourceforge.net
Subject: Re: [Geomoose-users] Wms layer showing pinkish tiles.
Franz,
I pasted your mapbook settings into mine - red tiles resulting.
When changing the projection to *projection="EPSG:4326"* it works well.
I think in the mapbook you have to define the projection in which the
WMS is available. GeoMoose takes care of reprojecting this on the fly
into the one you use for your application.
Nils
FRANZ OKYERE schrieb:
> Hi Nils,
> In my mapsource I have the following
>  <map-source name='nasa' type='wms' tiled='false' projection='EPSG:2264'
> width='512' height='512'>
>   <url>http://onearth.jpl.nasa.gov/wms.cgi</url>
>   <layer name="global_mosaic"/>
>   <param name="format" value="image/jpeg"/>
>  </map-source>
> In my catalog;
>   <layer title="Sati" src="nasa/global_mosaic" status="on"/>
> Franz
>  > From: coffee at uni-bonn.de
>  > To: franzzoa at hotmail.com; geomoose-users at lists.sourceforge.net
>  > Date: Fri, 11 Dec 2009 23:04:03 +0100
>  > Franz,
>  > maybe an error in your syntax? As well, the WMS might not
>  > be available at times or too slow (as happened to me when
>  > using NASA WMS).
>  > What did you put in your mapbook?
>  > Nils
>  > On Fri, 11 Dec 2009 18:53:17 +0000
>  > FRANZ OKYERE <franzzoa at hotmail.com> wrote:
>  > > Hi all, I thought in GM2, to use a wms service all you
>  > >need is to define it in the mapsource and then the
>  > >catalog..why then is my wms layer showing a pinkish
>  > >background after it has connected to the wms server?
>  > >Thanks. Franz Okyere. GIS specialist, SIT, Accra Ghana.
>  > > _________________________________________________________________
>  > > Got more than one Hotmail account? Save time by linking
>  > >them together
>  > > http://clk.atdmt.com/UKM/go/186394591/direct/01/
> New! Receive and respond to mail from other email accounts from within
> Hotmail Find out how. <http://clk.atdmt.com/UKM/go/186394593/direct/01/ >
> Return on Information:
> Google Enterprise Search pays you back
> Get the facts.
> http://p.sf.net/sfu/google-dev2dev
> Geomoose-users mailing list
> Geomoose-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
Nils Zierath
Department of Ecology and Resource Management
Walter-Flex-Strasse 3
53113 Bonn (Germany)
Tel.:   +49 (0) 228 - 73-1793
FAX:    +49 (0) 228 - 73-1889
E-Mail: nils.zierath at uni-bonn.de
Web:    http://www.coffee.uni-bonn.de
         http://www.zef.de
This SF.Net email is sponsored by the Verizon Developer Community
Take advantage of Verizon's best-in-class app development support
A streamlined, 14 day to market process makes app distribution fast and easy
Join now and get one step closer to millions of Verizon customers
http://p.sf.net/sfu/verizon-dev2dev
Name: Rick Moore.vcf
Type: text/x-vcard
Desc: Rick Moore.vcf
Url : http://lists.osgeo.org/pipermail/geomoose-users/attachments/20091216/36585863/RickMoore.vcf
More information about the Geomoose-users mailing list
