[Geomoose-users] Geomoose 2.x Problems
Dan Little danlittle at yahoo.com
Wed Dec 16 12:10:50 EST 2009
http://swoosh.co.wabasha.mn.us/geomoose/php/all_js.php
This is a brutally simple script, so if it doesn't work there is issues with the PHP install, right now I'm betting PHP is segfaulting...
Thanks for the heads up about the 2.0.1 MS4W zip file... I'll need to be more careful into the future about checking the MS4W release package.
----- Original Message ----
> From: "Gertken, Shawn" <sgertken at co.wabasha.mn.us>
> To: geomoose-users at lists.sourceforge.net
> Sent: Wed, December 16, 2009 11:08:01 AM
> Subject: Re: [Geomoose-users] Geomoose 2.x Problems
> I discovered there was a problem with the php CGI web service configuration in
> IIS. I believe I have it configured correctly now, but when I try to access the
> links you listed through a web browser, I now receive a CGI error. I know I've
> had issues with PHP scripts not playing nicely with IIS with the previous
> version of GeoMoose, and I'm not sure if this is the issue here.
> If you point your browser to http://swoosh.co.wabasha.mn.us/geomoose/php/ you
> will see a list of the files and directories, if that gives you any insight to
> the problem.
> Also, I downloaded the following installation package:
> http://www.geomoose.org/downloads/GeoMOOSE-2.0.1-MS4W.zip
> Shawn R. Gertken
> Wabasha County GIS Coordinator
> 651-565-5164
> -----Original Message-----
> From: Dan Little [mailto:danlittle at yahoo.com]
> Sent: Wednesday, December 16, 2009 10:01 AM
> To: Gertken, Shawn; geomoose-users at lists.sourceforge.net
> Here's the problem:
> For some reason the PHP folder is not being served, or you're missing the
> ALL_JS.PHP script.  Which package did you start from for the download? I'm just
> curious as we've tried to ship production-ready packages with compiled.js as the
> main script, instead of the dynamic loading scripts.
> In any case,  you can do further testing by uncommenting this:
> And commenting out
> You still may have some more issues to figure out because to use the rest of the
> services the PHP directory should be active and ready to run PHP services.
> This:
> http://swoosh.co.wabasha.mn.us/geomoose/php/itemquery.php
> Timed out on me... indicating there's something goofy going on with the IIS
> configuration, is there something like  a "Serve Subfolders, PLEASE" check box?
> Or maybe your PHP filter is trying to EXECUTE the "php" folder becauase a filter
> pattern is neglecting to recognize the ".php" as different than anything with
> "php" in it?
> >Sent: Wed, December 16, 2009 9:35:39 AM
> >Subject: [Geomoose-users] Geomoose 2.x Problems
> >I’ve decided to make the jump to GeoMoose 2.x;
> >however, I’ve run into a brick wall and decided to ask for some
> >assistance.
> >I suspect the problem may be with my configuration…I’m
> >using IIS and I have two sites running on the server. The primary site is an
> ArcIMS
> >site, with GeoMoose being the secondary site. I had no issues running the 1.x
> >version of Geomoose, but with different configuration files for 2.x, I’m
> >stuck with a site looking like this:
> >http://swoosh.co.wabasha.mn.us/geomoose/wabasha.html
> >I’ve noticed the following HTML throws up an error
> >flag in Firebug: . I’m far from an
> >HTML expert, so this leaves me at a loss.
> >I know there are potentially hundreds
> >of issues that could be causing the issues with my site, but does anyone have
> >any suggestions on where I might start?? Thanks for any help!
> >Shawn R. Gertken
> >Wabasha County GIS
> >Coordinator
> >411 Hiawatha Dr. E
> >Wabasha, MN 55981
> >651-565-5164
> >http://www.co.wabasha.mn.us/gis/
> This SF.Net email is sponsored by the Verizon Developer Community
> Take advantage of Verizon's best-in-class app development support
> A streamlined, 14 day to market process makes app distribution fast and easy
> Join now and get one step closer to millions of Verizon customers
> http://p.sf.net/sfu/verizon-dev2dev
> Geomoose-users mailing list
> Geomoose-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users mailing list
