[Geomoose-users] Any way to open a video file
Fischer, Brian bfischer at houstoneng.com
Fri Feb 13 12:25:05 EST 2009
Ed,
This could be done by making a hyperlink in the table of contents out of
that path to the video and open it in a new window.  My other thought is
you could easily duplicate the identify service, but revise it so it
only works on that one layer.  Then when someone identifies it you could
directly popup the video in a new window.  The trick is to set the
display="window" attribute in the service definition.  Should be pretty
easy to do.
-Brian
Brian Fischer
Houston Engineering, Inc.
Maple Grove, MN
(763) 493-4522
From: Edward E. Boesenberg, III [mailto:eboesenberg at niraengineers.com]
Sent: Friday, February 13, 2009 11:03 AM
To: geomoose-users at lists.sourceforge.net
Subject: [Geomoose-users] Any way to open a video file
I have a shapefile that has an attribute for the location of a video
(mpeg).  Is there anyway to have Geomoose open that video file once its
highlighted?
Ed
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20090213/f5d3859d/attachment.html
More information about the Geomoose-users mailing list
