[Geomoose-users] Only the top layer shows up when I print toPDF.
Fischer, Brian bfischer at houstoneng.com
Fri Feb 20 09:02:05 EST 2009
It could also be a scale dependency issue.  The printed map is usually at a difference scale that what you see on the screen.
Brian Fischer
Houston Engineering, Inc.
Maple Grove, MN
(763) 493-4522
Sent: Friday, February 20, 2009 7:39 AM
To: Edward E. Boesenberg, III; geomoose-users at lists.sourceforge.net
Subject: Re: [Geomoose-users] Only the top layer shows up when I print toPDF.
Is the layer set to transparent in the mapfile?
From: "Edward E. Boesenberg, III" <eboesenberg at niraengineers.com>
To: geomoose-users at lists.sourceforge.net
Sent: Friday, February 20, 2009 7:08:22 AM
Subject: [Geomoose-users] Only the top layer shows up when I print to PDF.
When I print the map to PDF I only get the top layer in the output.  I don’t have opacity set for any layer.  What am I doing wrong?
Thanks,
Ed
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20090220/56bd4238/attachment.html
More information about the Geomoose-users mailing list
