[Geomoose-users] Problem with Geomoose in Internet Explorer
Brent Fraser bfraser at geoanalytic.com
Tue Feb 24 14:09:38 EST 2009
Did you change the PROJECTION definition in the mapserver .map files to use the same projection as specified in your xxx_configuration.js?
Actually the important thing is the coordinates in the various extent settings (INITIAL_VIEW and Jump-To in the xxx_configuration.js ) must make sense for the PROJECTION object in the Mapserver map file(s) your are using.   The projection you specify via MAP_COORDINATE_SYSTEM in the xxx_configuration.js is only for lat/lon portion of the real-time coordinate readout shown in the status area for the mouse movements over the map.
Brent Fraser
Edward E. Boesenberg, III wrote:
> The mapbook file and the config file is attached.
> I modified two things in the config file, the “Jump to” information and
> coordinate system.
> I modified the list of layers in the xml file.
> *From:* Dan Little [mailto:danlittle at yahoo.com]
> *Sent:* Tuesday, February 24, 2009 1:01 PM
> *To:* Edward E. Boesenberg, III; geomoose-users at lists.sourceforge.net
> *Subject:* Re: [Geomoose-users] Problem with Geomoose in Internet Explorer
> It could be any one of the following:
> 1) An error in the Mapbook.
> 2) An error in the config.js.
> IE and FF use radically different parsers for both of these tasks and
> they differ in how forgiving they are.  If you can attach either the
> mapbook or the config.js then I/we can take a look to see where there
> may be an error.
> *From:* "Edward E. Boesenberg, III" <eboesenberg at niraengineers.com>
> *To:* geomoose-users at lists.sourceforge.net
> *Sent:* Tuesday, February 24, 2009 11:58:38 AM
> *Subject:* [Geomoose-users] Problem with Geomoose in Internet Explorer
> My Geomoose setup works perfectly in Firefox but when I try to use it in
> Internet Explorer (IE) I get a blank map.  The County Demo works using
> IE but I started my Geomoose app by modifying the State Demo and now it
> doesn’t work in IE.
> Any ideas?
> Ed
> Open Source Business Conference (OSBC), March 24-25, 2009, San Francisco, CA
> -OSBC tackles the biggest issue in open source: Open Sourcing the Enterprise
> -Strategies to boost innovation and cut costs with open source participation
> -Receive a $600 discount off the registration fee with the source code: SFAD
> http://p.sf.net/sfu/XcvMzF8H
> Geomoose-users mailing list
> Geomoose-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users mailing list
