[Geomoose-users] Label, Seach and label angle
John Kummun boache578 at yahoo.com
Thu Jan 8 15:12:15 EST 2009
hi guys,
i have 3 problems:
1. how do you break long label into, like 2 words per line. i used
WRAP " " but it only breaks at every space.
2. In the search for parcel by name, the "name" field in the attribute table is in upper case. This means that the user has to enter only capital letters in the search textbox otherwise it can't search for it. Is there a way that i can change the CASE of the seach item in the runtime so that it wouldn't matter the what case the search item is?
3. What is the  syntax if you want to set LABEL ANGLE to some field values in the attribute table?
Any ideas about any of these problems are welcome.
Thanks
John
Indiana
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20090108/c2243f73/attachment.html
More information about the Geomoose-users mailing list
