[Geomoose-users] Label, Seach and label angle
Dan Little danlittle at yahoo.com
Thu Jan 8 15:15:14 EST 2009
1) I think is a general mapserver conundrum.
2) You should be able to change the "FILTER" to FILTER /%...%/i ... The "i" makes the search case insensitive.
3) The old way to do it was to set "ANGLEITEM [fieldname]" now I believe you can simply use ANGLE [fieldName] I don't remember if it is in rads or degs.
To: geomoose-users at lists.sourceforge.net
Sent: Thursday, January 8, 2009 2:12:15 PM
Subject: [Geomoose-users] Label, Seach and label angle
hi guys,
i have 3 problems:
1. how do you break long label into, like 2 words per line. i used
WRAP " " but it only breaks at every space.
2. In the search for parcel by name, the "name" field in the attribute table is in upper case. This means that the user has to enter only capital letters in the search textbox otherwise it can't search for it. Is there a way that i can change the CASE of the seach item in the runtime so that it wouldn't matter the what case the search item is?
3. What is the  syntax if you want to set LABEL ANGLE to some field values in the attribute table?
Any ideas about any of these problems are welcome.
Thanks
John
Indiana
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20090108/ee7dfb36/attachment.html
More information about the Geomoose-users mailing list
