[Geomoose-users] GM feature report
Mark Volz MarkVolz at co.lyon.mn.us
Thu Jul 2 12:20:56 EDT 2009
Matt,
I also had this issue with the feature reports.  There are a couple short
term solutions that would be possible.
1) Limit the number of characters on your shapefile field length to force the
legal to fit in place.  For example you could have one of the lines set to
[legal1] the second to [legal 2] etc....
2) Make the field that could potentially be long show up on the left side of
the feature report, then remove any field on the right side of the map.  See
http://geomoose.lyonco.org/geomoose/php/LyonMain_print_report.php?layers=Parc
els,Roads,Railroads,Municipalities,Standard%20Background&title=Lyon%20County%
20Parcel%20Report&qitem=PARCEL_ID&qstring=09-012002-0&qlayer=Parcels&buffer=2
00 for an example.
Mark Volz
GIS Specialist
Lyon County, MN
Message: 3
Date: Thu, 2 Jul 2009 09:54:03 -0500
From: "Matthew D. Syvertson" <msyvertson at co.richland.nd.us>
Subject: [Geomoose-users] Feature Report
To: <geomoose-users at lists.sourceforge.net>
Message-ID:
	<9016EBD923E046409692B00D9D4C3FA7CFBA04 at co39dc1.co.richland.nd.us>
Content-Type: text/plain; charset="us-ascii"
I apologize if you have seen this on the developer list, but I did not
receive any responses from developers, so I am now hoping a user can
help me with my issue. Below is the posting:
Hello all,
I am encountering a problem regarding the parcel report called from the
popup feature in the Geomoose 2 sample application.   I have customized
the form (parcel.xml) to put the fields I need in there, but one of the
fields is a very long and runs off the edge of the page.  Is there any
possible way to make this field "wrap" so that it can fit?
The script for the report is feature_report.php
Thanks in advance for your assistance.
Matt Syvertson
Richland County GIS Coordinator
418 2nd Ave N
Wahpeton, ND 58075
msyvertson at co.richland.nd.us <mailto:matthews at co.richland.nd.us>
Voice: 701-642-7860  Fax: 701-642-7746
More information about the Geomoose-users mailing list
