[Geomoose-users] Couple of questions
t faustino
geomatrix3d at gmail.com
Fri Jul 10 08:56:26 EDT 2009
GeoMoose v1.6.1
On parcel search: I added a parcel and simply replaced the demo
shapefile of the same name; I know my parameters within my parcel are
not the same and I get this error on Search;
loadMap(): Web application error. Parameter 'id' value fails to
validate. msEvalRegex(): Regular expression error. String (83a-78)
failed expression test.
What is the Parameter 'id' referring to?
Can someone quickly run down how to add popups?
I know from reading that a popups="true" need be in the
configuration.xml but where is the popup reading from? mapfile? a
separately created xml page?
Labels seems to be giving me problems; I simply can't get labels to
show; I know this is more of a mapserver issue but if someone could
tell me if labeling is a known issue/bug in GeoMoose.
Thanks for your time folks.
Antonio
"If one advances confidently in the direction of his dreams, and
endeavors to live the life which he has imagined, he will meet with a
success unexpected in common hours." ~Thoreau
More information about the Geomoose-users
