[Geomoose-users] Zooming in
Brian Fischer bfischer at houstoneng.com
Fri Jul 10 12:54:42 EDT 2009
Matt, the scales are not documented very well in GM2 yet.  They are defined in the mapbook and are tied to the zoomlevels as defined by OpenLayers.  We have talked about trying to translate these numbers into real scales based on the coordinate system you are using, but for now they are set as resolutions of the max scale.  Here is the OpenLayers documention on it. http://trac.openlayers.org/wiki/SettingZoomLevels
Also here is the configuration parameter you would use for the GM 2 mapbook.  <param name="scales">1,2,4,8,12,16,24,32,64</param>
Brian Fischer, CFM  GIS Project Manager
Houston Engineering, Inc.
Phone: W: 763.493.4522 / M: 763.229.2734
From: Matthew D. Syvertson [mailto:msyvertson at co.richland.nd.us]
Sent: Wednesday, July 08, 2009 4:50 PM
To: geomoose-users at lists.sourceforge.net
Subject: [Geomoose-users] Zooming in
One other question for all you smart people:
I would love to be able to zoom closer than 1:864, but currently that seems to be a limitation.  How can I change that?
Thanks.
Matt Syvertson
Richland County GIS Coordinator
418 2nd Ave N
Wahpeton, ND 58075
msyvertson at co.richland.nd.us<mailto:matthews at co.richland.nd.us>
Voice: 701-642-7860  Fax: 701-642-7746
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20090710/4edef86e/attachment.html
More information about the Geomoose-users mailing list
