[Geomoose-users] direct connect to SID files
Bob Basques Bob.Basques at ci.stpaul.mn.us
Mon Jul 27 17:49:19 EDT 2009
All,
I (we) can second the stuff about the performance issues with large MRSID files.  We tried them once, and decided to use straight JPEG tiles instead.  The JP2k files were a big issue too, and since the read only aspect of the tiles didn't really require JP2000 files, we didn't put any more effort into it.
The JPG files have worked out very well for us, and run very fast from a tiled datastore.
bobb
>>> "Mark Volz" <MarkVolz at co.lyon.mn.us> wrote:
Matt,
Here is an example of how to directly connect to a local raster.  It is
reprojecting a sid on the fly.
###Begin file
MAP
NAME 'TestSid'
STATUS ON
IMAGETYPE JPEG
TRANSPARENT TRUE
Projection  #Of the Map
        "proj=lcc"
       'lat_1=44.25'
'lat_2=44.58333333333334'
    'lat_0=44.19555555555555'
    'lon_0=-95.85000000000001'
    'x_0=152400.3048006096'
    'y_0=30480.06096012192'
    'a=6378559.758'
    'b=6357173.65471281'
     "units=ft"
        "no_defs"
   END #projection
  LAYER
          NAME 'FSA 2006 SID'
          DATA 'naip_1-1_2n_s_mn083_2006_1.sid'
          STATUS DEFAULT
          TYPE RASTER
    PROJECTION #UTM-15N (projection of the data)
       "init=epsg:26915"
     END #projection
  END #LAYER
END ## end Map
###End File
However there are a couple issues with this:
1) I don't think mapserver is compiled to work with JP2000 files.
2) Mapserver is not very fast at displaying large rasters.  You might want to
consider using zoom scales, or perhaps have someone assist you with building
tiles.
Mark Volz
GIS Specialist
Lyon County, MN
>From: Matthew D. Syvertson <msyvertson at co.richland.nd.us>
>To: geomoose-users at lists.sourceforge.net
>Sent: Monday, July 27, 2009 3:39:49 PM
>Subject: [Geomoose-users] Problem with Rasters
>Hello to all,
>I hope someone has a sample map file that can help me out.  I currently have
WMS layers that serve as my background imagery, but I need to switch to file
based rasters, because I am having a few issues.  BUT, I cannot get mine to
work.  Here are the specific potential problems:
>-      MR SID format
>-      Very large
>-      Different projection from the main map
>If you have a map file that has helped you to serve up a rasterwith these
constraints, I would appreciate a chance to view the .map file.  If you don?t
have a sample, but have pointers for me I wouldappreciatethis help as well.
>I know this seems to be a mapserver issue, but I have tried the
documentation at that site also with no help?
>Matt Syvertson
>Richland County GIS Coordinator
>418 2nd Ave N
>Wahpeton, ND 58075
>Voice: 701-642-7860  Fax: 701-642-7746
Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day
trial. Simplify your report design, integration and deployment - and focus on
what you do best, core application coding. Discover what's new with
Crystal Reports now.  http://p.sf.net/sfu/bobj-july
Geomoose-users mailing list
Geomoose-users at lists.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20090727/3b512553/attachment.html
More information about the Geomoose-users mailing list
