[Geomoose-users] Fade Effect Step Value
Brian Fischer bfischer at houstoneng.com
Tue Jun 2 17:05:19 EDT 2009
Jessica,
There is no configuration variable for that.  You would have to dig into the javascript code and make the change in there.  Not sure where it is buried in the javascript code.
Brian Fischer, CFM  GIS Project Manager
Houston Engineering, Inc.
Phone: W: 763.493.4522 / M: 763.229.2734
From: Jessica Fendos [mailto:Jessica.Fendos at state.mn.us]
Sent: Tuesday, June 02, 2009 12:08 PM
To: geomoose-users at lists.sourceforge.net
Subject: [Geomoose-users] Fade Effect Step Value
Hi:
I know that we can control MAP_FADE_EFFECTS to be true or false and change the MAP_FADE_EFFECTS_DURATION in the configuration.js file. However, how can I change the step value for the fade effect so that fading occurs more drastically? Can someone advise? Thanks!
Jessica
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20090602/8312d1c9/attachment.html
More information about the Geomoose-users mailing list
