[Geomoose-users] Fade Effect Step Value
Dan Little danlittle at yahoo.com
Tue Jun 2 17:25:58 EDT 2009
The code is buried in Map.js.
To: Jessica Fendos <Jessica.Fendos at state.mn.us>; "geomoose-users at lists.sourceforge.net" <geomoose-users at lists.sourceforge.net>
Sent: Tuesday, June 2, 2009 4:05:19 PM
Subject: Re: [Geomoose-users] Fade Effect Step Value
Jessica,
There is no configuration variable for that.  You would have to
dig into the javascript code and make the change in there.  Not sure where it
is buried in the javascript code.
Brian
Fischer,CFM  GIS Project Manager
Houston Engineering, Inc.
Phone: W: 763.493.4522 / M: 763.229.2734
[mailto:Jessica.Fendos at state.mn.us]
Sent: Tuesday, June 02, 2009 12:08 PM
To: geomoose-users at lists.sourceforge.net
Subject: [Geomoose-users] Fade Effect Step Value
Hi:
I know that we can
control MAP_FADE_EFFECTS to be true or false and change the
MAP_FADE_EFFECTS_DURATION in the configuration.js file. However, how can I
change the step value for the fade effect so that fading occurs more
drastically? Can someone advise? Thanks!
Jessica
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20090602/707bc586/attachment.html
More information about the Geomoose-users mailing list
