[Geomoose-users] [Geomoose-developers] Project Raster ont he fly
Mark Volz MarkVolz at co.lyon.mn.us
Thu Jun 4 09:00:37 EDT 2009
Jay,
We are projecting rasters on the fly.  Attached below is a copy of one of our
maps that projects from UTM to County Coordinates.  It sounds like you will
just need to switch the two projection blocks around then replace the Lyon
County Coordinates with your county coordinate system.
You can also supply the ESPG codes as well.  I have my projection parameters
inline, either should be fine.
MAP
            NAME 'FSA2008'
            STATUS ON
            UNITS FEET
            Projection  #Lyon County Coordinates  (the projection of the map)
            "proj=lcc"
                        'lat_1=44.25'
                        'lat_2=44.58333333333334'
                        'lat_0=44.19555555555555'
                        'lon_0=-95.85000000000001'
                        'x_0=152400.3048006096'
                        'y_0=30480.06096012192'
                        'a=6378559.758'
                        'b=6357173.65471281'
                        "units=ft"
            "no_defs"
            END #projection
            LAYER
                        NAME         lmic_fsa2008
                        TYPE         RASTER
                        STATUS       DEFAULT
                        CONNECTIONTYPE WMS
                        CONNECTION
"http://geoint.lmic.state.mn.us/cgi-bin/wms?"
                        METADATA
                                    "wms_srs" "EPSG:26915"
                                    "wms_name" "fsa2008"
                                    "wms_server_version" "1.1.1"
                                    "wms_format" "image/jpeg"
                                    "wms_styles" ""
                                    "wms_exceptions"
"application/vnd.ogc.se_inimage"
                        END
                        Projection  #UTM15 (the projection of the data)
                                    "proj=lcc"
                                    "lat_1=-76.66666666666667"
                                    "lat_2=-79.33333333333333"
                                    "lat_0=-90"
                                    "lon_0=96"
                                    "x_0=0"
                                    "y_0=0"
                                    "ellps=WGS84"
                                    "datum=WGS84"
                                    "units=m"
                                    "no_defs"
                        END #Projection
            END#layer
END#map
Mark Volz
GIS Specialist
Lyon County, MN
(507) 532-8218
From: Jay Kapalczynski [mailto:jkapalczynski at ci.maple-grove.mn.us]
Sent: Wednesday, May 27, 2009 9:13 AM
To: geomoose-users at lists.sourceforge.net;
geomoose-developers at lists.sourceforge.net
Subject: [Geomoose-developers] Project Raster ont he fly
If I have a SID file that I know is in Henn Projection...what do I need to do
to get GeoMOOSE to read this file and reproject it to UTMNAD83 Zone 15 Meters
THanks
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20090604/bef4397b/attachment.html
More information about the Geomoose-users mailing list
