[Geomoose-users] Select layer
Dan Little danlittle at yahoo.com
Mon Jun 29 15:08:08 EDT 2009
I think we'll need a better description, can you attach the entire .map file and a screenshot?
To: geomoose-users at lists.sourceforge.net
Sent: Monday, June 29, 2009 2:04:35 PM
Subject: [Geomoose-users] Select layer
Trying to define my selectable layers, I keep getting a "./select.map" comment returned in information window rather than the attribute I specified.
My layer is in the mapbook service area for Select feature.
My select.map @ maps_countydemo includes my layer;
LAYER # Firestations Layer
              NAME 'Firestations'
            DATA 'countydata/firestations/ga_firestations2'
            STATUS ON
            TYPE POINT
            METADATA
                qstring_validation_pattern '.'
            END
              HEADER 'countydata/firestations/select_header.html'
            TEMPLATE 'countydata/firestations/select_firestations.html'
            FOOTER 'countydata/firestations/select_footer.html'
            TOLERANCE 2
                CLASS
                        NAME 'Firestations'
                        COLOR 255 0 0
                        SYMBOL "square"
                        SIZE 8
        END
..and I have a select_firestations.html located in the data folder:
Could someone advise what I am overlooking?
Thanks in advance.
Antonio
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20090629/7f5416da/attachment.html
More information about the Geomoose-users mailing list
