[Geomoose-users] Select layer
Brent Fraser bfraser at geoanalytic.com
Mon Jun 29 15:54:58 EDT 2009
Are you displaying the results to the side panel or a separate window?  Which browser are you using?
t faustino wrote:
> Trying to define my selectable layers, I keep getting a "./select.map"
> comment returned in information window rather than the attribute I
> specified.
> My layer is in the mapbook service area for Select feature.
> My select.map @ maps_countydemo includes my layer;
> LAYER # Firestations Layer
>               NAME 'Firestations'
>             DATA 'countydata/firestations/ga_firestations2'
>             STATUS ON
>             TYPE POINT
>             METADATA
>                 qstring_validation_pattern '.'
>             END
>               HEADER 'countydata/firestations/select_header.html'
>             TEMPLATE 'countydata/firestations/select_firestations.html'
>             FOOTER 'countydata/firestations/select_footer.html'
>             TOLERANCE 2
>                 CLASS
>                         NAME 'Firestations'
>                         COLOR 255 0 0
>                         SYMBOL "square"
>                         SIZE 8
>         END
> ..and I have a select_firestations.html located in the data folder:
> Could someone advise what I am overlooking?
> Thanks in advance.
> Antonio
> Geomoose-users mailing list
> Geomoose-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users mailing list
