[Geomoose-users] Geomoose
Brent Fraser bfraser at geoanalytic.com
Fri Mar 27 12:06:56 EDT 2009
Heather,
The server (MapServer) does the (re)projection of the source data (e.g. air photos).  You need to specify the coordinate system of the source data in the LAYER portion of MapServer's MAP file, then MapServer will re-project the imagery when rendering the layer.
Brent Fraser
GeoAnalytic Inc.
Dan Little wrote:
> Unfortunately not, we don't do any reprojection in Javascript/XML.
> ----- Original Message ----
>> From: Mark Volz <MarkVolz at co.lyon.mn.us>
>> To: Heather Wirth <HWIRTH at co.benton.mn.us>; geomoose-users at lists.sourceforge.net
>> Sent: Friday, March 27, 2009 10:50:22 AM
>> Subject: Re: [Geomoose-users] Geomoose
>> Hi,
>> Does anyone know if you can include the reprojection parameters within the
>> mapbook.xml file?
>> Heather,
>> I am not sure if you can include the parameters to reproject from UTM to
>> another coordinate system strait out of the mapbook.xml file.
>> What we do is reference the air photo in a .map file - like every other
>> layer.
>> I have attached a map file for the 2008 LMIC FSA WMS Service.
>> Mark Volz
>> GIS Specialist
>> Lyon County, MN
>> (507) 532-8218
>> -----Original Message-----
>> From: Heather Wirth [mailto:HWIRTH at co.benton.mn.us]
>> Sent: Friday, March 27, 2009 10:38 AM
>> To: Mark Volz
>> Subject: Geomoose
>> Mark,
>> I have been having a Geomoose problem that I think you may have
>> conquered already.
>> Question Number One: I noticed, on your geomoose site, that you have
>> the 2008 FSA orthos.  Are you getting those from LMIC's WMS, or serving
>> those locally?  Lyon County's site is listed as an example application
>> on LMIC's website, so I am assuming you are using the WMS.
>> Question Number Two: Does your application use Lyon County coordinates,
>> or UTM?
>> Question Number Three: If you are using Lyon County coordinates, how
>> did you get the LMIC photo to reproject?
>> Your help is much appreciated.
>> Heather Wirth
>> GIS Specialist
>> Benton County
> Geomoose-users mailing list
> Geomoose-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users mailing list
