[Geomoose-users] Feature requests and a Tip
Dan Little danlittle at yahoo.com
Tue May 5 15:46:01 EDT 2009
Hey Brent thank you for the feature requests and the tip...
Here's something you might want to look into for 4/5...
You can actually do "dependent" layers in side of GM2 right now AND use mapserver "layer" levels ... for example...
<map-source name="labels">
<file>all/labels.map</file>
<layer name="county"/>
<layer name="city"/>
<layer name="street"/>
</map-source>
<map-source name="shapes">
<file>all/shapes.map</file>
</map-source>
Then in the <catalog>, to implement "requires..."
<layer title="Cities" src="labels/city:shapes/city" status="on"/>
<layer title="County" src="labels/county:shapes/county" status="on"/>
Or to implement mapfile level layering...
<group title="Labels">
<layer title="City" src="labels/city"/>
<layer title="County" src="labels/county"/>
</group>
<group title="Streets">
<layer title="Labels" src="labels/street"/>
<layer title="Lines" src="shapes/street"/>
</group>
----- Original Message ----
> From: Brent Fraser <bfraser at geoanalytic.com>
> To: GeoMOOSE Users List <geomoose-users at lists.sourceforge.net>
> Sent: Tuesday, May 5, 2009 2:35:07 PM
> Subject: [Geomoose-users] Feature requests and a Tip
> A few feature requests for Geomoose 2:
> 1. Make the side panel collapsible like v1.6.1
> 2. On clicking the Search button, set the keyboard focus to the text box.
> 3. Have check box at the Group level to turn off/on entire sets of layers.
> 4. Have dependent layers (like Mapserver's LAYER -> REQUIRES) so if I turn a
> layer off, it's labels (rendered in a separate map file so they are always on
> top of everything else) will turn off too.
> 5. Have check boxes for the Mapserver LAYER level too.
> And here's a tip for those who like to maximize their mapping:
>     When using the browser (Firefox, IE, etc) on a GeoMoose site, press F11 to
> switch to Full-screen mode while in the browser.  This will get rid of all those
> pesky browser title, status, tool, and menu bars.  Press F11 again to return to
> standard windowed browsing.  But don't try this with dual (or more!) display
> setups; Mapserver is set by default to render a maximum of 2048 and the layers
> will fail to render (for those building GeoMoose sites, set the MAP's MAXSIZE to
> 4096 or larger to handle dual displays).
> Best Regards,
> Brent Fraser
> GeoAnalytic Inc.
> The NEW KODAK i700 Series Scanners deliver under ANY circumstances! Your
> production scanning environment may not be a perfect world - but thanks to
> Kodak, there's a perfect scanner to get the job done! With the NEW KODAK i700
> Series Scanner you'll get full speed at 300 dpi even with all image
> processing features enabled. http://p.sf.net/sfu/kodak-com
> Geomoose-users mailing list
> Geomoose-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users mailing list
