[Geomoose-users] GM2 - direct call to WMS without mapfile
Dan Little danlittle at yahoo.com
Thu May 14 10:04:54 EDT 2009
I have the WMS layer reprojection working in SVN.
And I even wrote some documentation...
http://www.geomoose.org/geomoose2/docs/howto/wms_project.html
I've tested going from UTM-15 to EPSG:4326 (using the nasa world mosaic you posted earlier).
----- Original Message ----
> From: Dan Little <danlittle at yahoo.com>
> To: coffee at uni-bonn.de
> Cc: GeoMoose Mailing list <geomoose-users at lists.sourceforge.net>
> Sent: Tuesday, May 12, 2009 7:12:39 AM
> Subject: Re: [Geomoose-users] GM2 - direct call to WMS without mapfile
> The error is with the reprojection. I will research what it will take to get
> this to work today and see if I can get a solution.
> > From: CoFIS Web
> > To: Dan Little
> > Sent: Tuesday, May 12, 2009 7:09:28 AM
> > Hi Dan,
> > my output projection for GM is EPSG:32637 as defined in the mapbook defaults.
> > Nils
> > Dan Little schrieb:
> > > Hi Nils,
> > > What is your map projection?
> > >> From: CoFIS Web
> > >> To: GeoMoose Mailing list
> > >> Sent: Tuesday, May 12, 2009 6:38:29 AM
> > >> Subject: [Geomoose-users] GM2 - direct call to WMS without mapfile
> > >> Dear all,
> > >> do I understand correctly, that in GM2 I can include WMS into my
> application
> > without having to us a local mapfile?
> > >> I try to include the Blue Marble Global Mosaic tiled WMS
> > (http://onearth.jpl.nasa.gov/wms.cgi?request=GetTileService) using the
> following
> > lines in my mapbook:
> > >>         src="background-wms/global_mosaic"/>
> > >> When loading the layer, GM (according to the status bar in Firefox) loads
> > data. However, the only thing displayed are red tiles - no satellite images.
> > >> Could someone please point me in the right direction what to change?
> > >> Thanks,
> > >> Nils
> > >> -- Center for Development Research
> > >> Department of Ecology and Resource Management
> > >> Walter-Flex-Strasse 3
> > >> 53113 Bonn (Germany)
> > >> Tel.:   +49 (0) 228 - 73-1793
> > >> FAX:    +49 (0) 228 - 73-1889
> > >> E-Mail: coffee at uni-bonn.de
> > >> Web:    http://www.cofis.info/atlas
> > >>          http://www.coffee.uni-bonn.de
> > >> The NEW KODAK i700 Series Scanners deliver under ANY circumstances! Your
> > >> production scanning environment may not be a perfect world - but thanks to
> > >> Kodak, there's a perfect scanner to get the job done! With the NEW KODAK
> i700
> > >> Series Scanner you'll get full speed at 300 dpi even with all image
> > processing features enabled. http://p.sf.net/sfu/kodak-com
> > >> _______________________________________________
> > >> Geomoose-users mailing list
> > >> Geomoose-users at lists.sourceforge.net
> > >> https://lists.sourceforge.net/lists/listinfo/geomoose-users
> i700
> processing
> Kodak, there's a perfect scanner to get the job done! With the NEW KODAK i700
More information about the Geomoose-users mailing list
