[Geomoose-users] GM2 - direct call to WMS without mapfile
Dan Little
danlittle at yahoo.com
Tue May 12 08:12:39 EDT 2009
The error is with the reprojection. I will research what it will take to get this to work today and see if I can get a solution.
----- Original Message ----
> From: CoFIS Web <coffee at uni-bonn.de>
> To: Dan Little <danlittle at yahoo.com>
> Cc: GeoMoose Mailing list <geomoose-users at lists.sourceforge.net>
> Sent: Tuesday, May 12, 2009 7:09:28 AM
> Subject: Re: [Geomoose-users] GM2 - direct call to WMS without mapfile
> Hi Dan,
> my output projection for GM is EPSG:32637 as defined in the mapbook defaults.
> Nils
> Dan Little schrieb:
> > Hi Nils,
> > What is your map projection?
> >> From: CoFIS Web
> >> To: GeoMoose Mailing list
> >> Sent: Tuesday, May 12, 2009 6:38:29 AM
> >> Subject: [Geomoose-users] GM2 - direct call to WMS without mapfile
> >> Dear all,
> >> do I understand correctly, that in GM2 I can include WMS into my application
> without having to us a local mapfile?
> >> I try to include the Blue Marble Global Mosaic tiled WMS
> (http://onearth.jpl.nasa.gov/wms.cgi?request=GetTileService) using the following
> lines in my mapbook:
> >> src="background-wms/global_mosaic"/>
> >> When loading the layer, GM (according to the status bar in Firefox) loads
> data. However, the only thing displayed are red tiles - no satellite images.
> >> Could someone please point me in the right direction what to change?
> >> Thanks,
> >> Nils
> >> -- Center for Development Research
> >> Department of Ecology and Resource Management
> >> Walter-Flex-Strasse 3
> >> 53113 Bonn (Germany)
> >> Tel.: +49 (0) 228 - 73-1793
> >> FAX: +49 (0) 228 - 73-1889
> >> E-Mail: coffee at uni-bonn.de
> >> Web: http://www.cofis.info/atlas
> >> http://www.coffee.uni-bonn.de
> >> The NEW KODAK i700 Series Scanners deliver under ANY circumstances! Your
> >> production scanning environment may not be a perfect world - but thanks to
> >> Kodak, there's a perfect scanner to get the job done! With the NEW KODAK i700
> >> Series Scanner you'll get full speed at 300 dpi even with all image
> processing features enabled. http://p.sf.net/sfu/kodak-com
> >> _______________________________________________
> >> Geomoose-users mailing list
> >> Geomoose-users at lists.sourceforge.net
> >> https://lists.sourceforge.net/lists/listinfo/geomoose-users
> > Series Scanner you'll get full speed at 300 dpi even with all image processing
More information about the Geomoose-users
