[Geomoose-users] Info from Select to a new window?
Dan Little
danlittle at yahoo.com
Thu May 28 15:15:06 EDT 2009
Thanks Brain ... I was going to post almost exactly what you wrote there but have found myself rather busy. LOL...
----- Original Message ----
> From: Brian Fischer <bfischer at houstoneng.com>
> To: Brent Fraser <bfraser at geoanalytic.com>; Dan Little <danlittle at yahoo.com>
> Cc: GeoMOOSE Users List <geomoose-users at lists.sourceforge.net>
> Sent: Thursday, May 28, 2009 1:43:20 PM
> Subject: RE: [Geomoose-users] Info from Select to a new window?
> Brent,
> This use to work, but haven't tried it in a while. You could set the display
> attribute of the service tag to display="window" and it would pop the results up
> in a new window. Give that a try. Here is the documentation we wrote on it:
> http://www.geomoose.org/moose/index.php?option=com_content&task=view&id=14&Itemid=29
> Look at the display attribute under section.
> Also I had Dan write a little custom feature for me to create a link to open the
> results tab up in a new window so users could print it. I think he mainly did
> it with some JavaScript and CSS. Here is the app that is doing that.
> http://klamathcounty.houstoneng.com/klamathmap/klamathmap.html Select some
> parcels with the mailing labels tool or Identify tool then click on the "Print
> Info. Tab" in the menubar.
> Hope this helps,
> Brian
> Brian Fischer, CFM GIS Project Manager
> Houston Engineering, Inc.
> Phone: W: 763.493.4522 / M: 763.229.2734
> -----Original Message-----
> From: Brent Fraser [mailto:bfraser at geoanalytic.com]
> Sent: Thursday, May 28, 2009 11:36 AM
> To: Dan Little
> Subject: Re: [Geomoose-users] Info from Select to a new window?
> Dan,
> I'm using V1.6.1.
> It looks like the target of the html/text generated by select.php is set around
> line 488 in ServiceManager.js (of course I could be totally out-to-lunch as my
> JavaScript is weak):
> } else if(returnType.match(/text/i) || contentType.match(/plain/i)){ //
> Plain Text Return
> var results = document.getElementById('content_results_form');
> var text = http.responseText;
> if(!(text.match(/\
> text = text.replace(/\n/g,'
\n');
> text = ''+text+'';
> results.innerHTML = text;
> EventManager.triggerEvent('changetab',TABS_RESULTS_NAME);
> } else if(returnType.match(/csv/i) || contentType.match(/csv/i)) { // CSV
> return type
> perhaps if do something like:
> var win = window.open("", "Results", "width=100, height=100,
> scrollbars=yes" );
> var results2 = win.document.body;
> results2.innerHTML = text;
> Any thoughts on that?
> Thanks!
> Brent
> Dan Little wrote:
> > 1.6 or 2.0?
> >> From: Brent Fraser
> >> To: GeoMOOSE Users List
> >> Sent: Wednesday, May 27, 2009 11:35:08 AM
> >> Subject: [Geomoose-users] Info from Select to a new window?
> >> I'd like to send the attribute information of my selected features to a new
> >> browser window instead of the Information tab. What's a good way to do this?
> >> Thanks!
> >> Brent Fraser
> >> Register Now for Creativity and Technology (CaT), June 3rd, NYC. CaT
> >> is a gathering of tech-side developers & brand creativity professionals. Meet
> >> the minds behind Google Creative Lab, Visual Complexity, Processing, &
> >> iPhoneDevCamp as they present alongside digital heavyweights like Barbarian
> >> Group, R/GA, & Big Spaceship. http://p.sf.net/sfu/creativitycat-com
> >> _______________________________________________
> >> Geomoose-users mailing list
> >> Geomoose-users at lists.sourceforge.net
> >> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users
