[Geomoose-users] Select Info to a new window
Brent Fraser
bfraser at geoanalytic.com
Fri May 29 11:58:57 EDT 2009
I had a look at the HTML generated by the SELECT service (not the IDENTIFY):
<html xmlns:moose="http://geomoose.org/"><head>
<moose:mapbook>
<moose:map title='Highlight' default='true'>
<moose:file>../../TopoCan/select.map</moose:file> <moose:param name='layers' value='Wells'/> <moose:param name='qlayer'
It doesn't render very well when sent to a new window (using the display="window" tag in the Select service.)
Any thoughts on how to fix this?
Thanks!
Brent
Brent Fraser wrote:
> Brian,
> I just found the display tag while sifting thru ServiceManager.js It seems to work ok for Identify, but for Select it opens a new window and prints the value of the map tag, e.g:
> ./select.map
> strange...
> Many Thanks!
> Brent
> Brian Fischer wrote:
>> Brent,
>> This use to work, but haven't tried it in a while. You could set the display attribute of the service tag to display="window" and it would pop the results up in a new window. Give that a try. Here is the documentation we wrote on it:
>> http://www.geomoose.org/moose/index.php?option=com_content&task=view&id=14&Itemid=29 Look at the display attribute under <service> section.
>> Also I had Dan write a little custom feature for me to create a link to open the results tab up in a new window so users could print it. I think he mainly did it with some JavaScript and CSS. Here is the app that is doing that. http://klamathcounty.
> houstoneng.com/klamathmap/klamathmap.html Select some parcels with the mailing labels tool or Identify tool then click on the "Print Info. Tab" in the menubar.
>> Hope this helps,
>> Brian
>> Brian Fischer, CFM GIS Project Manager
>> Houston Engineering, Inc.
>> Phone: W: 763.493.4522 / M: 763.229.2734
>> -----Original Message-----
>> From: Brent Fraser [mailto:bfraser at geoanalytic.com]
>> Sent: Thursday, May 28, 2009 11:36 AM
>> To: Dan Little
>> Cc: GeoMOOSE Users List
>> Subject: Re: [Geomoose-users] Info from Select to a new window?
>> Dan,
>> I'm using V1.6.1.
>> It looks like the target of the html/text generated by select.php is set around line 488 in ServiceManager.js (of course I could be totally out-to-lunch as my JavaScript is weak):
>> } else if(returnType.match(/text/i) || contentType.match(/plain/i)){ // Plain Text Return
>> var results = document.getElementById('content_results_form');
>> var text = http.responseText;
>> if(!(text.match(/\<html/))) {
>> text = text.replace(/\n/g,'<br/>\n');
>> text = '<tt>'+text+'</tt>';
>> results.innerHTML = text;
>> EventManager.triggerEvent('changetab',TABS_RESULTS_NAME);
>> } else if(returnType.match(/csv/i) || contentType.match(/csv/i)) { // CSV return type
>> perhaps if do something like:
>> var win = window.open("", "Results", "width=100, height=100, scrollbars=yes" );
>> var results2 = win.document.body;
>> results2.innerHTML = text;
>> Any thoughts on that?
>> Thanks!
>> Brent
>> Dan Little wrote:
>>> 1.6 or 2.0?
>>> ----- Original Message ----
>>>> From: Brent Fraser <bfraser at geoanalytic.com>
>>>> To: GeoMOOSE Users List <geomoose-users at lists.sourceforge.net>
>>>> Sent: Wednesday, May 27, 2009 11:35:08 AM
>>>> Subject: [Geomoose-users] Info from Select to a new window?
>>>> I'd like to send the attribute information of my selected features to a new
>>>> browser window instead of the Information tab. What's a good way to do this?
>>>> Thanks!
>>>> Brent Fraser
>>>> Register Now for Creativity and Technology (CaT), June 3rd, NYC. CaT
>>>> is a gathering of tech-side developers & brand creativity professionals. Meet
>>>> the minds behind Google Creative Lab, Visual Complexity, Processing, &
>>>> iPhoneDevCamp as they present alongside digital heavyweights like Barbarian
>>>> Group, R/GA, & Big Spaceship. http://p.sf.net/sfu/creativitycat-com
>>>> _______________________________________________
>>>> Geomoose-users mailing list
>>>> Geomoose-users at lists.sourceforge.net
>>>> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users
