[Geomoose-users] feature editing - able to add polygons, not able to delete or edit..
Mark Volz MarkVolz at co.lyon.mn.us
Mon Nov 16 09:15:23 EST 2009
Hello,
I was working with the feature editor.  I am able to add polygons, however I
am not able to delete or edit any.  If I recall correctly for the edit and
delete service reported a message similar to "no feature id was found".   Has
anyone come across this issue, or know how to take care of it?
I also noticed that some of the instructions in
http://www.geomoose.org/moose/docs/feature_editor.html may be incorrect or
outdated.  Please check
1.	 Should this be map-source?
		<map-service path="editor" type="mapserver">
<file>/var/www/geomoose2/maps/test_polygon/test_polygon.map</file>
		        <layer name="polygons"/>
		</map-service>
2.	Part of the modification to /css/user_tools.css has already been
completed.
Thanks
Mark Volz
GIS Specialist
Lyon County, MN
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20091116/6bc5ea28/attachment.html
More information about the Geomoose-users mailing list
