[Geomoose-users] XML command not working
Vojko Daneu vojko.daneu at mail.telepac.pt
Tue Oct 6 04:43:26 EDT 2009
Hallo,
I use the "Select Feature" service in the XML book and have defined a command within this service. The command's function (an alert window just to test) is in the header of the main html page. Unfortunately it does not work. See code below. Am I missing something?
Greetings, Vojko
This is the service defined in the XML book:
 <service title="Select Location" command="refreshParent()" default="true" locked="true" cursor="url(cursors/select.cur), auto" shape="point" type="inspect-search" icon="shared/images/toolbar/SelectLocationUp.png" highlight="shared/images/toolbar/SelectLocationDown.png">
  <url>select/0002/00011_selectLocation.php</url>
  <input type="point" name="coords" />
  <input type="hidden" name="map" value="GMS/data/0002/00011/positionsData/00011_select.map" />
  <input type="hidden" name="layer" value="Selected Positions:Number" />
  </service>
This is the function in defined in the header of the main GeoMoose html document:
<script type="text/javascript">
function refreshParent()
 alert('hallo');
</script>
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20091006/deb1c348/attachment.html
More information about the Geomoose-users mailing list
