[Geomoose-users] Problem adding a layer
Dan Little danlittle at yahoo.com
Tue Oct 6 13:02:09 EDT 2009
Sometimes it's easier to use the Firefox "Page Info" tool, then click on Media.  Scroll through the list until you find the offending layer, copy the URL and open it in a new window.
>From: "Edward E. Boesenberg, III" <eboesenberg at niraengineers.com>
>To: Len Kne <lkne at houstoneng.com>; Geomoose Support <geomoose-users at lists.sourceforge.net>
>Sent: Tuesday, October 6, 2009 10:39:22 AM
>Subject: Re: [Geomoose-users] Problem adding a layer
>I have Firebug installed, where
>do I look in firebug to see the GET call?
>From:Len Kne
>[mailto:lkne at houstoneng.com]
>Sent: Monday, October 05, 2009 3:45 PM
>To: 'Edward E. Boesenberg, III'; Geomoose Support
>Subject: RE: [Geomoose-users] Problem adding a layer
>Edward
>If the demo layers work, then
>“mapserver_url” is set correct in the mapbook, which would point towards path
>problems in the map file.  Another issue could be extents in either the
>mapbook or map file.
>A real helpful tool for trouble
>shooting is Firebug in the Firefox browser.  Using firebug, you can
>isolate the GET call to the server – I like to copy the URL GeoMOOSE is sending
>and run it directly from the browser – this way you will see MapServer errors.
>Len
>From:Edward E.
>Boesenberg, III [mailto:eboesenberg at niraengineers.com]
>Sent: Monday, October 05, 2009 12:52 PM
>To: Geomoose Support
>Subject: [Geomoose-users] Problem adding a layer
>I just installed a new server and Geomoose 2.0 and I am
>trying to add a layer but I am having problems. I reprojected all my data to
>EPSG 2915 so there is no projection error.
>I included below snippets from my mapbook and mapfile.
>Does anybody see what’s wrong?
><map-source
>name="muni_bndy" type="mapserver">
><file>./demo/muni_bndy/muni_bndy.map</file>
><layer name="all"/>
></map-source>
><layer title="muni_bndy" src="muni_bndy/all"
>status="on" legend="true"/>
>Here is my mapfile:
>MAP
>NAME 'muni_bndy'
>SIZE 800 650
>STATUS ON
>EXTENT  457272 4215829 1688276 5254002
>        UNITS METERS
>INCLUDE "../../geomoose_globals.map"
>WEB
>INCLUDE "../../temp_directory.map"
>END
>LEGEND
>      STATUS ON
>      LABEL
>TYPE TRUETYPE
>FONT vera_sans
>SIZE 8
>COLOR 0 0 0
>END
>END
>#    CONFIG PROJ_LIB
>"/ms4w/proj/nad"
>    Projection
>"init=epsg:26915"   # UTM Zone 15N
>    END
>LAYER
>NAME 'muni_bndy'
>DATA '//Nira-server/ms4w/apps/geomoose2/maps/demo/muni_bndy/muni_bndy.shp'
>TYPE LINE
>STATUS ON
>CLASS
>  NAME 'muni_bndy'
>  STYLE
>  COLOR 100 100 100
>END
>END
>MAXSCALE 1500000000
>END ## Layer
>END ## end Map
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20091006/48e5bd78/attachment.html
More information about the Geomoose-users mailing list
