[Geomoose-users] Problem adding a layer
Edward E. Boesenberg, III eboesenberg at niraengineers.com
Tue Oct 6 13:13:22 EDT 2009
I figured out what was wrong.
In the WEB section I needed to change the location of the temp_directory.map
Sent: Tuesday, October 06, 2009 1:02 PM
To: Edward E. Boesenberg, III; Len Kne; Geomoose Support
Subject: Re: [Geomoose-users] Problem adding a layer
Sometimes it's easier to use the Firefox "Page Info" tool, then click on Media.  Scroll through the list until you find the offending layer, copy the URL and open it in a new window.
From: "Edward E. Boesenberg, III" <eboesenberg at niraengineers.com>
To: Len Kne <lkne at houstoneng.com>; Geomoose Support <geomoose-users at lists.sourceforge.net>
Sent: Tuesday, October 6, 2009 10:39:22 AM
I have Firebug installed, where do I look in firebug to see the GET call?
Sent: Monday, October 05, 2009 3:45 PM
To: 'Edward E. Boesenberg, III'; Geomoose Support
Subject: RE: [Geomoose-users] Problem adding a layer
Edward
If the demo layers work, then “mapserver_url” is set correct in the mapbook, which would point towards path problems in the map file.  Another issue could be extents in either the mapbook or map file.
A real helpful tool for trouble shooting is Firebug in the Firefox browser.  Using firebug, you can isolate the GET call to the server – I like to copy the URL GeoMOOSE is sending and run it directly from the browser – this way you will see MapServer errors.
Len
From: Edward E. Boesenberg, III [mailto:eboesenberg at niraengineers.com]
Sent: Monday, October 05, 2009 12:52 PM
To: Geomoose Support
Subject: [Geomoose-users] Problem adding a layer
I just installed a new server and Geomoose 2.0 and I am trying to add a layer but I am having problems. I reprojected all my data to EPSG 2915 so there is no projection error.
I included below snippets from my mapbook and mapfile.  Does anybody see what’s wrong?
<map-source name="muni_bndy" type="mapserver">
                                <file>./demo/muni_bndy/muni_bndy.map</file>
                                <layer name="all"/>
                </map-source>
                <layer title="muni_bndy" src="muni_bndy/all" status="on" legend="true"/>
Here is my mapfile:
MAP
                NAME 'muni_bndy'
                SIZE 800 650
                STATUS ON
                EXTENT  457272 4215829 1688276 5254002
        UNITS METERS
                INCLUDE "../../geomoose_globals.map"
                WEB
                                INCLUDE "../../temp_directory.map"
                END
                LEGEND
                      STATUS ON
                      LABEL
                                TYPE TRUETYPE
                                FONT vera_sans
                                SIZE 8
                                COLOR 0 0 0
                      END
                END
#    CONFIG PROJ_LIB "/ms4w/proj/nad"
    Projection
                "init=epsg:26915"   # UTM Zone 15N
    END
LAYER
                NAME 'muni_bndy'
                DATA '//Nira-server/ms4w/apps/geomoose2/maps/demo/muni_bndy/muni_bndy.shp'
                TYPE LINE
                STATUS ON
                CLASS
                  NAME 'muni_bndy'
                  STYLE
                  COLOR 100 100 100
                END
                END
                MAXSCALE 1500000000
END ## Layer
END ## end Map
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20091006/69572746/attachment.html
More information about the Geomoose-users mailing list
