[Geomoose-users] No image when printing to PDF at highest setting
Len Kne lkne at houstoneng.com
Wed Oct 7 10:07:35 EDT 2009
How about this...
If the layers are being provided by a WMS, the size of the image you are requesting may be larger than the service will provide - not much you can do about that.  For GM2.0 MapServer sources, make sure the following line is in geomoose_globals.map or in each map file:
MAXSIZE 10000
Len
From: Edward E. Boesenberg, III [mailto:eboesenberg at niraengineers.com]
Sent: Wednesday, October 07, 2009 8:45 AM
To: Len Kne; 'Geomoose Support'
Subject: RE: [Geomoose-users] No image when printing to PDF at highest setting
No, the image doesn't show up in the Image or HTML
Sent: Wednesday, October 07, 2009 9:27 AM
To: 'Edward E. Boesenberg, III'; Geomoose Support
Can you see an image with "View Image" or "View HTML" when on the highest setting?
Len
Sent: Wednesday, October 07, 2009 8:15 AM
To: Geomoose Support
Subject: [Geomoose-users] No image when printing to PDF at highest setting
When I print to PDF on letter size and have the quality set to highest there is no map image within the border but it works with the other quality settings.
Is there a way to get the highest quality setting to work?
CADD / GIS Manager
Nira Consulting Engineers, Inc.
www.niraengineers.com
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20091007/227d21e8/attachment.html
More information about the Geomoose-users mailing list
