[Geomoose-users] No image when printing to PDF at highest setting
Edward E. Boesenberg, III eboesenberg at niraengineers.com
Wed Oct 7 12:41:36 EDT 2009
That worked.  The layers are all served by Mapserver and I added MAXSIZE
10000 to the Geomoose_globals.map
Thanks
Sent: Wednesday, October 07, 2009 10:08 AM
To: 'Edward E. Boesenberg, III'; 'Geomoose Support'
Subject: RE: [Geomoose-users] No image when printing to PDF at highest
setting
How about this.
If the layers are being provided by a WMS, the size of the image you are
requesting may be larger than the service will provide - not much you can do
about that.  For GM2.0 MapServer sources, make sure the following line is in
geomoose_globals.map or in each map file:
MAXSIZE 10000
Len
From: Edward E. Boesenberg, III [mailto:eboesenberg at niraengineers.com]
Sent: Wednesday, October 07, 2009 8:45 AM
To: Len Kne; 'Geomoose Support'
setting
No, the image doesn't show up in the Image or HTML
Sent: Wednesday, October 07, 2009 9:27 AM
To: 'Edward E. Boesenberg, III'; Geomoose Support
setting
Can you see an image with "View Image" or "View HTML" when on the highest
setting?
Len
Sent: Wednesday, October 07, 2009 8:15 AM
To: Geomoose Support
Subject: [Geomoose-users] No image when printing to PDF at highest setting
When I print to PDF on letter size and have the quality set to highest there
is no map image within the border but it works with the other quality
settings.
Is there a way to get the highest quality setting to work?
CADD / GIS Manager
Nira Consulting Engineers, Inc.
www.niraengineers.com
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20091007/b4877843/attachment.html
More information about the Geomoose-users mailing list
