[Geomoose-users] Identify Attributes on a WMS
Brian Fischer bfischer at houstoneng.com
Wed Apr 21 16:43:11 EDT 2010
Liesa,
First thing you will have to figure out is if the WMS source has setup any attributes to return with a getinfo wms request.  It should be published in the GetCapbilities if it is.  Not all WMS servers are setup by default to return all attributes.
I have never tried to use the identify with a WMS data source, but I believe Dan added support for it.  I have seen there are configuration settings for the html templates in settings.ini file.
Brian Fischer, CFM  GIS Project Manager
Houston Engineering, Inc.
Phone: Direct: 763-493-6664 / W: 763.493.4522 / M: 763.229.2734
From: Miller, Elizabeth (DOT) [mailto:Elizabeth.Miller at state.mn.us]
Sent: Wednesday, April 21, 2010 3:07 PM
To: geomoose-users at lists.sourceforge.net
Subject: [Geomoose-users] Identify Attributes on a WMS
I'm looking for help in setting up an identify on a wms layer. I am using a mapfile to bring in the layer rather than setting up the connection in the mapbook. Does anyone have an example of how to do this? I would like to be able to click with the identify tool on the layer and return attributes in an html template.
Thanks!
Liesa Miller
MnDOT Metro District
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20100421/e827d50d/attachment.html
More information about the Geomoose-users mailing list
