[Geomoose-users] Identify Attributes on a WMS
Brian Fischer bfischer at houstoneng.com
Thu Apr 22 13:16:46 EDT 2010
In your mapfile that you are trying to identify on are you using?
                                METADATA
                                                'wms_record'    'identify_parcel.html'
                                END
I believe that is what tells the GeoMOOSE code to make a WMS identify request versus a MapServer identify request.  Have you look to see what firebug is return for results?  When I look through the identify.php code it appears to all be in there, but it is looking for the wms_record parmater in the mapfile.
Like I said I have not tried to use this feature myself but it is suppose to be supported.  Hope this helps you debug it a little bit more.
Brian Fischer, CFM  GIS Project Manager
Houston Engineering, Inc.
Phone: Direct: 763-493-6664 / W: 763.493.4522 / M: 763.229.2734
From: Miller, Elizabeth (DOT) [mailto:Elizabeth.Miller at state.mn.us]
Sent: Thursday, April 22, 2010 11:52 AM
To: Brian Fischer; geomoose-users at lists.sourceforge.net
Subject: RE: Identify Attributes on a WMS
Thanks Brian,
Yep, the WMS source should have attributes available for request. Here's my current METADATA code. As you can see, I think I've thrown everything but the kitchen sink in there. If you have any ideas or see any glaring errors let me know.
LAYER...
   METADATA
      "wms_identify" "identify_data.html"
      "wms_record" "identify_data.html"
      "wms_title" "layertitle"
      "wms_srs" "EPSG:26915"
      "wms_name" "layername"
      "wms_server_version" "1.1.1"
      "wms_format" "image/gif"
      "wms_styles" ""
      "wms_exceptions" "application/vnd.ogc.se_inimage"
      "wms_request" "GetMap"
      "wms_request" "GetFeatureInfo"
      "wms_include_items" "all"
      "wms_feature_info_mime_type" "text/html"
    END
    DUMP TRUE
    TEMPLATE '/ms4w/.../identify_data.html'
    TOLERANCE 3
...END
From: Brian Fischer [mailto:bfischer at houstoneng.com]
Sent: Wednesday, April 21, 2010 3:43 PM
To: Miller, Elizabeth (DOT); geomoose-users at lists.sourceforge.net
Liesa,
First thing you will have to figure out is if the WMS source has setup any attributes to return with a getinfo wms request.  It should be published in the GetCapbilities if it is.  Not all WMS servers are setup by default to return all attributes.
I have never tried to use the identify with a WMS data source, but I believe Dan added support for it.  I have seen there are configuration settings for the html templates in settings.ini file.
Sent: Wednesday, April 21, 2010 3:07 PM
To: geomoose-users at lists.sourceforge.net
Subject: [Geomoose-users] Identify Attributes on a WMS
I'm looking for help in setting up an identify on a wms layer. I am using a mapfile to bring in the layer rather than setting up the connection in the mapbook. Does anyone have an example of how to do this? I would like to be able to click with the identify tool on the layer and return attributes in an html template.
Thanks!
Liesa Miller
MnDOT Metro District
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20100422/dffb3565/attachment.html
More information about the Geomoose-users mailing list
