[Geomoose-users] Setting buffer select units
Dara Olson dolson at glifwc.org
Tue Apr 27 12:05:27 EDT 2010
Is there a way to set buffer select units different than the ground units defined in the mapbook?  I am using WGS84 (4326) and would like to buffer select based on meters, feet or miles and not degrees.
Any help would be greatly appreciated.
Dara
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20100427/6fbc5cf7/attachment.html
More information about the Geomoose-users mailing list
