[Geomoose-users] Setting buffer select units
Dan Little danlittle at yahoo.com
Tue Apr 27 12:54:27 EDT 2010
Hm.. yes, there is.  What version of GeoMOOSE are you using?  Is there any chance you can use a meters-based projection instead?  By doing the conversion from DD to a measure unit is a real fallacy because it changes DRASTICALLY based on where on the planet the user is trying to measure.
>From: Dara Olson <dolson at glifwc.org>
>To: geomoose-users at lists.sourceforge.net
>Sent: Tue, April 27, 2010 11:05:27 AM
>Subject: [Geomoose-users] Setting buffer select units
>Is there a way to set buffer select units different
>than the ground units defined in the mapbook?  I am using WGS84 (4326) and
>would like to buffer select based on meters, feet or miles and not
>degrees.
>Any help would be greatly appreciated.
>Dara
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20100427/31fc6f1b/attachment.html
More information about the Geomoose-users mailing list
