[Geomoose-users] Setting buffer select units
Dara Olson dolson at glifwc.org
Tue Apr 27 14:58:36 EDT 2010
We are using GeoMoose 2.2.  Our data covers three states (Michigan, Minnesota & Wisconsin), so we have all of our postgis data in WGS84.  We want to eventually view the data in webmercator, but we are concerned with speed/performance because we would be reprojecting a lot of layers on the fly.  Currently we have over 200 layers with many more layers to be added.  Will reprojecting that many layers significantly effect performance?  Or would it be better to decrease accuracy in measuring distance and calculating acreage because of the projection (WGS84)?  We would using the buffer tool for selecting waterbodies within a certain distance.  Any thoughts or suggestions would be greatly appreciated!
Miigwech!
Dara
  ----- Original Message -----
  To: Dara Olson ; geomoose-users at lists.sourceforge.net
  Sent: Tuesday, April 27, 2010 11:54 AM
  Subject: Re: [Geomoose-users] Setting buffer select units
  Hm.. yes, there is.  What version of GeoMOOSE are you using?  Is there any chance you can use a meters-based projection instead?  By doing the conversion from DD to a measure unit is a real fallacy because it changes DRASTICALLY based on where on the planet the user is trying to measure.
    To: geomoose-users at lists.sourceforge.net
    Sent: Tue, April 27, 2010 11:05:27 AM
    Subject: [Geomoose-users] Setting buffer select units
    Is there a way to set buffer select units different than the ground units defined in the mapbook?  I am using WGS84 (4326) and would like to buffer select based on meters, feet or miles and not degrees.
    Any help would be greatly appreciated.
    Dara
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20100427/9240bc45/attachment.html
More information about the Geomoose-users mailing list
