[Geomoose-users] Mailing Lists Search
Brent Fraser
bfraser at geoanalytic.com
Mon Aug 9 09:57:05 EDT 2010
I couldn't get it to work either. And I don't think Google is able to index the
mailing list. Perhaps we should mirror/archive it through Nabble?
Brent
Reynolds, Michael J. (DOT) wrote:
> I must be doing something wrong since searching any of the keywords individually returns zero results.
> 1) From this form: http://sourceforge.net/search/?group_id=160935&type_of_search=mlists
> 2) I fill in query: Geomoose, select both mailing lists (or individually)
> 3) fill in the start date 2010-01-01 and end date 2010-08-09
> 4) click the Search button.
> Zero results.
> I've tried changing the query to identify.php, identify, openlayers, etc...
> Maybe there's a different search form I should be using?
> -----Original Message-----
> From: Len Kne [mailto:lkne at houstoneng.com]
> Sent: Friday, August 06, 2010 9:26 AM
> To: Reynolds, Michael J. (DOT); geomoose-users at lists.sourceforge.net
> Subject: Re: [Geomoose-users] Identify tool
> Seems to be working, but not very friendly. It appears that it is only searching the body of the emails (not the subject lines) and it does not make partial word matches. So in the recent exchanges on the Identify tool, so if you search for "Identify", it does not see "identify.php" as a match. I tried using a wildcard in the search, but that was rejected as a syntax error.
> Do we need to see if there are options to loosen up the search in SourceForge.
> Len
> From: Reynolds, Michael J. (DOT) [mailto:Mike.Reynolds at state.mn.us]
> Sent: Friday, August 06, 2010 7:30 AM
> To: geomoose-users at lists.sourceforge.net
> Anyone else have trouble doing a search on the mailing list articles at:
> I've tried several different methods filling in the form and clicking the search button but I don't get any results. Including search for keyword "MAP", select the user group from the list and inputting both dates.... nada.
> This SF.net email is sponsored by
> Make an app they can't live without
> Enter the BlackBerry Developer Challenge http://p.sf.net/sfu/RIM-dev2dev _______________________________________________
> Geomoose-users mailing list
> Geomoose-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users
