[Geomoose-users] Mailing Lists Search
Reynolds, Michael J. (DOT) Mike.Reynolds at state.mn.us
Mon Aug 9 07:27:29 EDT 2010
I must be doing something wrong since searching any of the keywords individually returns zero results.
1) From this form: http://sourceforge.net/search/?group_id=160935&type_of_search=mlists
2) I fill in query: Geomoose, select both mailing lists (or individually)
3) fill in the start date 2010-01-01 and end date 2010-08-09
4) click the Search button.
Zero results.
I've tried changing the query to identify.php, identify, openlayers, etc...
Maybe there's a different search form I should be using?
-----Original Message-----
Sent: Friday, August 06, 2010 9:26 AM
To: Reynolds, Michael J. (DOT); geomoose-users at lists.sourceforge.net
Subject: Re: [Geomoose-users] Identify tool
Seems to be working, but not very friendly.  It appears that it is only searching the body of the emails (not the subject lines) and it does not make partial word matches.  So in the recent exchanges on the Identify tool, so if you search for "Identify", it does not see "identify.php" as a match.  I tried using a wildcard in the search, but that was rejected as a syntax error.
Do we need to see if there are options to loosen up the search in SourceForge.
Len
From: Reynolds, Michael J. (DOT) [mailto:Mike.Reynolds at state.mn.us]
Sent: Friday, August 06, 2010 7:30 AM
To: geomoose-users at lists.sourceforge.net
Anyone else have trouble doing a search on the mailing list articles at:
I've tried several different methods filling in the form and clicking the search button but I don't get any results.  Including search for keyword "MAP", select the user group from the list and inputting both dates....  nada.
This SF.net email is sponsored by
Make an app they can't live without
Enter the BlackBerry Developer Challenge http://p.sf.net/sfu/RIM-dev2dev _______________________________________________
Geomoose-users mailing list
Geomoose-users at lists.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users mailing list
