[Geomoose-users] Pink screen on zoom in
Brent Fraser bfraser at geoanalytic.com
Thu Aug 12 15:02:20 EDT 2010
OpenLayers (used by Geomoose) will display a pink screen if for some reason it
didn't get an image from the server (e.g. it either got nothing, or some text).
  It's common to get that when your mapserver map file has a syntax error or it
has a path problem to your source data.  That doesn't seem to be your case since
you do get an image displayed a at 1:22k.  Is the source data of the layer
raster or vector? which format?
  Use Firefox's Firebug (the Net tab) or IE 8 (Tools -> Developer Tools to have
a look at the conversations between the client and server.  Likely mapserver is
sending an error message...
Best Regards,
Brent Fraser
BATES Cress A (Lane Cty) wrote:
> I'm new to Geomoose but have been making progress on getting the demo to
> work and adding a layer of my own.  My new layer displays fine until I
> zoom in a certain amount.  It's ok at 1:22677 (as shown in scale window
> at bottom of screen); but as soon as I try to zoom in further I get the
> pink screen.  I've tried changing the initial_extents and max_extents in
> the mapbook.xml file; and have also changed the max and initial extents
> in the compiled.js file with no luck.  I've also changed the "SIZE"
> parameter in the mapserver mapfile from "800 650" to "400 300" with no
> luck.  I'm not sure how the zoom scales are controlled with Geomoose to
> prevent this from happening.  However, the demo data for Dakota County
> Parcels zooms in just fine.  I'm missing some connection.  I'm using
> Geomoose 2.2 and trying to run the app in IE 8.
> Thanks,
> Cress Bates
> Lane County Public Works - GIS
> cress.bates at co.lane.or.us
More information about the Geomoose-users mailing list
