[Geomoose-users] Measure Tool
Len Kne
lkne at houstoneng.com
Mon Aug 16 10:59:45 EDT 2010
Hi Paul
One way to get around this is to use the navigation buttons and slider that are on the map itself. You can use those to pan and zoom without removing control from the measure tool.
Getting this functionality to work with the toolbar tools would be a bit of work. Each tool that interacts with the map is a control and only one control can be active at a time (for example, you could not have zoom and pan on at the same time because GeoMOOSE would not know what to do with your mouse movements). It would be possible to come up with key combinations which change the control behavior (for example holding the control key while measuring allows free-hand drawing) to do what you are looking for, but that would require people knowing about these special combinations. The trend in web maps seems to be towards fewer controls. The trend seems to be towards fewer controls, removing Pan from the toolbar might be one option so people have to use the on-map navigation buttons.
Len
From: Wirth, Paul [mailto:Paul.Wirth at kniferiver.com]
Sent: Monday, August 16, 2010 8:47 AM
To: 'geomoose-users at lists.sourceforge.net'
Subject: [Geomoose-users] Measure Tool
To Everybody,
I came across something that I would like to see work better.
Sometimes I have to zoom in to see the roads or where I will start and grab the measure distance tool, click on where I will start and then pan to find the finish point. When I pan the measure distance tool clicks off and I cannot start where I left off. I must start from the beginning again. This happens with the sketch tool also. I would like it so I can start with the measure tool, pan and then start again where I left off ( a continuous unbroken line). Does anybody have a fix for that? Any ideas?
Paul Wirth
Knife River - Central Minnesota
4787 Shadow Wood Drive NE
Sauk Rapids, MN 56379
Phone: 320-229-3794
Fax: 320-251-0011
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20100816/550e1f45/attachment.html
More information about the Geomoose-users
