[Geomoose-users] Identify Error
Jacob Rodel jacob.rodel at co.todd.mn.us
Mon Aug 30 15:51:41 EDT 2010
I just started another application and the identify works fine in that.
My initial application is using the 900913 projection for google layers.
I see that there isn't an identify button in the web mercator demo.
Could the problem be a projection issue?
[defaults]
; Location of the default mapbook
mapbook=mapbook.xml
[map]
projection=EPSG:900913
; Do NOT forget trailing "/" in the paths!
[paths]
root=/ms4w/apps/trails/maps/
temp=/ms4w/tmp/ms_tmp/
mapserver_url=/cgi-bin/mapserv.exe
server_name=localhost
; MS4W settings
; root=/ms4w/apps/trails/maps/
; temp=/ms4w/tmp/ms_tmp/
Jacob Rodel
GIS Technician
Todd County GIS & Land Services Dept.
347 Central Ave. Suite 1
Long Prairie, MN 56347
(320) 732-4248
Sent: Monday, August 30, 2010 2:42 PM
To: Jacob Rodel; geomoose-users at lists.sourceforge.net
Subject: RE: Identify Error
Check that the "root" path is set correctly in settings.ini (there needs
to be a forward slash at the end of the line).
Len
From: Jacob Rodel [mailto:jacob.rodel at co.todd.mn.us]
Sent: Monday, August 30, 2010 1:21 PM
To: geomoose-users at lists.sourceforge.net
Subject: [Geomoose-users] Identify Error
When I try my identify button in an application I created I keep getting
this error message.  Fatal error: Call to a member function
queryByPoint() on a non-object in
C:\ms4w\apps\trails\htdocs\php\identify.php on line 125.     When I just
add my data to the demo and identify one of my layers it works fine.
I've been trying to figure this out for a bit now.  Could someone please
point me in the right direction?
Jacob Rodel
GIS Technician
(320) 732-4248
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20100830/bd6869da/attachment.html
More information about the Geomoose-users mailing list
