[Geomoose-users] Updated Post: Using Mapserver Filter
Rafe Hargrove rafeh91 at msn.com
Wed Feb 3 18:16:32 EST 2010
I would like to pass a parameter to mapserver's filter command so that I can filter out records for a person selected from a third party, Java/JSP application.  I see where I can pass a parameter in GeoMoose's map source definition.  Can I dynamically set this parameter based on a person selected from a separate Java/JSP application?  This application is used to identify the owner for which we would like to see a map of owned properties.  I would like to click on a URL which opens GeoMoose, SOMEHOW dynamically sets a selected ownerkey, and passes this value as a parameter to MapServer.  MapServer would use this parameter to dynamically set the Filter value.
Any ideas how best to do this in GeoMoose?
Thanks for any and all help,
Rafe
______________________________________________________________
MAP
 SIZE 800 650
 EXTENT -13888695.571283 2821332.743118 -8908902.824881 6340349.019812
 UNITS METERS
  STATUS ON
 PROJECTION
  "init=epsg:900913"
 END
 INCLUDE "../../geomoose_globals.map"
 LAYER
         NAME 'parcel'
         TYPE POLYGON
         STATUS ON
  OPACITY 30
      FILTER "ownerkey='%myownerkey%' "
  CONNECTIONTYPE postgis
         CONNECTION "user=postgres password=XXXXXX dbname=XXXXXX host=localhost"
         DATA 'wkb_geometry from (select gid, ownerkey, astext(wkb_geometry) as wkt_geometry, wkb_geometry from parcel) as myparcel using unique gid'
         CLASS
                NAME "parcel"
          style
          COLOR 0 150 0
           OUTLINECOLOR 0 255 0
          WIDTH 3
   end
  end
         METADATA
                 'identify_record' 'identify.html'
         END
 END
END
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20100203/4d9a3d29/attachment.html
More information about the Geomoose-users mailing list
