[Geomoose-users] GeoMOOSE and PostGIS Help
Len Kne lkne at houstoneng.com
Fri Jun 25 17:04:50 EDT 2010
Hi Rubin
What does Firebug say?  It usually gives good error messages for Postgres connection issues.
I believe that MapServer needs to have the geometry column entered in the geometry_columns table for the query to work.
Len
From: Rubin Seifert [mailto:rseifert at ci.faribault.mn.us]
Sent: Friday, June 25, 2010 2:22 PM
To: geomoose-users at lists.sourceforge.net
Subject: [Geomoose-users] GeoMOOSE and PostGIS Help
Hello Everyone,
I am having problems displaying postgis layers.  The postgis layer shows up pink.  If I use the shapefile, the layer displays correctly.
So, I have searched through the mail list archives, mapserver documentation, and postgis documentation with no luck.  I am thinking I missed something simple.  I am using MS4W version 2.3.1 and GeoMoose 2.2.  I have been able to connect to the database and view the data using QGIS.  So it has to be a mapserver problem right?
Here is the map file:
MAP ##
            NAME 'postgresql'
            STATUS ON
            UNITS METERS
            TRANSPARENT TRUE
            INCLUDE "../../geomoose_globals.map"
            LAYER
                        NAME "test"
                        CONNECTIONTYPE postgis
                        CONNECTION "host=localhost port=5432 dbname=geomoose user=gisadmin password=gis"
                        DATA "the_geom from test"
                        #DATA '../data/test.shp'
                        STATUS ON
                        TYPE line
                        CLASS
                           NAME 'PostGIS Test'
                          #STYLE
                                    # SYMBOL 'plainline'
                                    #SIZE 0.8
                                     COLOR 0 92 230
                         #END
                        END
            END # LAYER
END ## end Map
Any ideas are greatly appreciated, thanks.
Rubin
Rubin Seifert
GIS-CAD Tech.
City of Faribault
208 First Avenue N.W.
Faribault, MN 55021
Email: rseifert at ci.faribault.mn.us<mailto:rseifert at ci.faribault.mn.us>
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20100625/848fea67/attachment.html
More information about the Geomoose-users mailing list
