[Geomoose-users] GM 2 help and meta tag
Dan Little danlittle at yahoo.com
Tue Mar 23 09:28:56 EDT 2010
Hi Dieter,
The help and metadata tools were changed in GM2 because we actually have a much more flexible system for implementing layer controls.
To implement the metadata you should be able to do the following:
<catalog>
<layer title="Title" src="service/name" ... metadata="true">
<metadata>url to metadata information</metadata>
</layer>
</catalog>
If the "?" icon does not appear next to the layer make sure to check the "catalog.show_controls" setting, it must be set to "true."
<configuration>
<param name="catalog.show_controls" value="true"/>
</configuration>
----- Original Message ----
> From: Dieter Lehmann <dieter.lehmann at hfwu.de>
> To: geomoose-users at lists.sourceforge.net
> Sent: Fri, March 12, 2010 9:34:15 AM
> Subject: [Geomoose-users] GM 2 help and meta tag
> Hello,
I used GM1 with the help and meta-tag in the group-definition to
> link additional information to my data. But I struggle to get this working in
> GM2.
This was my definition in GM1:
>   <group title="Climate" expand="false">
>     <map title="temperature" default="true"
> reference="true">
> <file>./test.map</file>
> <meta>../meta/test.meta</meta>
>   <help>../download/climate.zip</help>
>     </map>
          <map
> </group>
In the docu I found that there should be a tag
<metadata>URL</metadata>
But this isn't
> working.
I tried also to set this
>         <param
> name="layer_controls.metadata.on">true</param>
without any
> effect.
Any idea? And the "help" disapeared?
Thanks,
Dieter
Download
> Intel® Parallel Studio Eval
Try the new software tools for yourself.
> Speed compiling, find bugs
proactively, and fine-tune applications for
> parallel performance.
See why Intel Parallel Studio got high marks during
> beta.
http://p.sf.net/sfu/intel-sw-dev
Geomoose-users
> mailing list
> href="mailto:Geomoose-users at lists.sourceforge.net">Geomoose-users at lists.sourceforge.net
> href="https://lists.sourceforge.net/lists/listinfo/geomoose-users" target=_blank
More information about the Geomoose-users mailing list
