[Geomoose-users] Geocode and Identify Errors
Wes Cleland wcleland at vanburencity.org
Fri May 21 15:14:53 EDT 2010
I made the changes and the geocode service works now. I don't know if it
should be placed in Trac or not, the reason is the demo map/mapbook
works, but when I change the mapbook to one that I altered it does not.
It seems as though there is another configuration that needs to be
changed somewhere. Any suggestions? I still get a "deprecated" error
when attempting to print; however, it still generates the files to
print. Thanks for the tip.
v/r,
Wesley T. Cleland, GISP, CFM
GIS Coordinator
City of Van Buren, Arkansas
479-471-5025
"One ought never to turn one's back on a threatened danger and try to
run away from it. If you do that, you will double the danger. But if you
meet it promptly and without flinching, you will reduce the danger by
half. Never run away from anything. Never!"
Winston Churchill
From: danlittle at yahoo.com [mailto:danlittle at yahoo.com]
Sent: Friday, May 21, 2010 8:21 AM
To: wcleland at vanburencity.org geomoose-users at lists.sourceforge.net
Subject: Re: [Geomoose-users] Geocode and Identify Errors
I'd suggest two things:
1) File a bug in Trac.
2) Edit both geocode.php and identify.php files and replace "split" with
"explode".  PHP does obnoxiously stupid things with strings and string
functions.
	To: geomoose-users at lists.sourceforge.net
	Sent: Thu, May 20, 2010 4:04:06 PM
	Subject: [Geomoose-users] Geocode and Identify Errors
	First off, I would like to say thanks for the assistance; these
mailing list are worth their weight in gold when it comes to someone
just starting out in a program such as myself. I started off using MS4W
and GeoMoose and after an abundance of use, was authorized to move to a
server. Due to funding issues Linux was the best route to go. So I am
not only learning more about GeoMoose, I am learning linux as well.
After some configuration and permission issues, I finally was able to
get GeoMoose to display in a web browser using FGS9.5 on linux. I can
pan, zoom-in, etc., however, when I search, identify, geocode, and print
I get an error. Usually along the lines of:
	Deprecated: Function split() is deprecated in
/opt/geomoose2/htdocs/php/geocode.php on line 22
	Warning: Cannot modify header information - headers already sent
by (output started at /opt/geomoose2/htdocs/php/geocode.php:22) in
/opt/geomoose2/htdocs/php/geocode.php on line 27
	This particular error is specific to geocoding obviously, but
they all contain the word deprecated and end in cannot modify header
information. When I attempt to identify, select, buffer I get an
unhandled request return Unknown error. I am stuck and any assistance
would be greatly appreciated. Thanks in advance.
	v/r,
	Wes Cleland
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20100521/eba7657e/attachment.html
More information about the Geomoose-users mailing list
