[Geomoose-users] Problem with createSprite.py
Gregory Roberts | Wendler groberts at wendlergs.com
Fri Apr 8 15:01:13 EDT 2011
This worked. Thank you very much Rubin!
Gregory
  _____
From: Rubin Seifert [mailto:rseifert at ci.faribault.mn.us]
Sent: Friday, April 08, 2011 1:11 PM
To: groberts at wendlergs.com
Subject: RE: [Geomoose-users] Problem with createSprite.py
Gregory,
Have you installed the python pil library.  Check out
http://www.pythonware.com/products/pil/.
Thanks.
Rubin
  _____
From: Gregory Roberts | Wendler [mailto:groberts at wendlergs.com]
Sent: Friday, April 08, 2011 12:24 PM
To: geomoose-users at lists.sourceforge.net
Subject: [Geomoose-users] Problem with createSprite.py
Hello,
I am attempting to run the createSprite.py tool for the first time. I am
following the directions from the geomoose website
(http://geomoose.org/docs/sprite.html), but I keep receiving an error when I
try to run createSprite.py>../htdocs/css/sprite.css
The error reads ImportError: No module named Image
A blank sprite.css file is produced. This is the first time I have tried to
use this so any help would be appreciated. Thanks!
Gregory
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20110408/d3b915f1/attachment.html
More information about the Geomoose-users mailing list
