[Geomoose-users] GM 2.4 RC1, Mapserver 6.0 beta 5
Brent Fraser bfraser at geoanalytic.com
Fri Apr 8 15:57:14 EDT 2011
John,
I ran into the olDiv problem in Dec
(http://sourceforge.net/mailarchive/message.php?msg_id=26773197):
 > And while 2.9 doesn't work with GeoMoose trunk, 2.9.1 seems to
 > work better with the exception of the cursor handling at line 850 in
 > main.js:
 > // Add cursors > var olDiv = >
document.getElementById('mapContainer_OpenLayers_ViewPort');
 > where olDiv gets set to null.
 > Replacing the line with
 > var olDiv =
document.getElementById('OpenLayers.Map_4_OpenLayers_ViewPort');
 > makes it work.
Best Regards,
Brent Fraser
On 4/8/2011 12:34 PM, John Callahan wrote:
> I just downloaded the latest versions of GeoMoose 2.4 RC1 for MS4W and
> MS4W 3.0.2.   I also updated MS4W to use Mapserver 6.0 beta5.   A few
> quick notes/questions I ran into:
> The GM demo showed a pink screen when first accessed.  To make the
> demo work, I had to do two things, thought the legends are off.  In
> geomoose_globals.map, change the OUTPUTFORMAT of jpeg to 'AGG/JPG', as
> GD/JPEG did not seem to be working (error: loadOutputFormat(): General
> error message. OUTPUTFORMAT clause references driver GD/JPEG, but this
> driver isn't configured.)  I couldn't tell if GD is being removed from
> MS6 or not.
> I also had to comment out the GAP and STYLE elements in symbol.sym.
> Apparently, STYLE was renamed to PATTERN and moved up to the STYLE
> section.  GAP was also moved to the STYLE section.
> (http://mapserver.org/trunk/mapfile/symbol.html)
> GM 2.4 ships with OpenLayers 2.8 but MS4W ships with OpenLayers 2.10.
> (I think OSGeo4W ships with OL 2.9 or 2.10.)   I pointed the GM demo
> to OL2.10 and  received this error: "olDiv is null".  Not that they
> have to match but could/should GM ship with OL2.10?
> As far as GeoMoose goes, and assuming all of my data are local, does
> it matter if my own data layers are Mapserver layers or WMS layers
> created by Mapserver?  Some of my data will be served as individual
> WMS layers anyway.  This is proabbly more of a Mapserver/mapscript
> question though.
> - John
> John Callahan, Research Scientist
> Delaware Geological Survey, University of Delaware
> URL: http://www.dgs.udel.edu
> Xperia(TM) PLAY
> It's a major breakthrough. An authentic gaming
> smartphone on the nation's most reliable network.
> And it wants your games.
> http://p.sf.net/sfu/verizon-sfdev
> Geomoose-users mailing list
> Geomoose-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20110408/d1f17646/attachment.html
More information about the Geomoose-users mailing list
