[Geomoose-users] caching and other ways to increase performance
Bistrais, Bob Bob.Bistrais at maine.gov
Fri Aug 5 13:43:36 EDT 2011
Thanks!
We're just starting to look at GeoWebCache here. I've loaded it onto the
development server and am figuring out how to configure it with our
data.
Sent: Saturday, July 30, 2011 11:17 PM
To: Brian Fischer; Bistrais, Bob; geomoose-users at lists.sourceforge.net
Subject: Re: [Geomoose-users] caching and other ways to increase
performance
MapProxy is a much better solution as it will use stored tiles to
generate scaled images.  This gets the tiled sources for the google like
mapping and interfaces and gets the pyramiding benefits of Bob's
solution.
	To: "Bistrais, Bob" <Bob.Bistrais at maine.gov>;
"geomoose-users at lists.sourceforge.net"
<geomoose-users at lists.sourceforge.net>
	Sent: Friday, July 29, 2011 3:28 PM
performance
	We have used Tilecache with GeoMOOSE a little bit.  Seems
tilecache is dying a bit in favor of GEoWebCache and MapProxy.
	We have also used ESRI rest map caches.  There are limitations
with these in that they are really only useful for basemap layers where
you don't need to do identify, selection and searches on them.  The
other complication is GeoMOOSE has very limited support for using these
type of map sources with the print service.  As of now the only one that
works is ESRI REST services.
	I've also been meaning to look into MapProxy
(http://mapproxy.org/).  I'm hoping to learn more about that at FOSS4G.
	Hope this helps.
	Brian Fischer, CFM
	GIS Manager
	Houston Engineering, Inc.
	O 763.493.4522 | D 763.493.6664 | M 763.229.2734
	From: Bistrais, Bob [mailto:Bob.Bistrais at maine.gov]
	Sent: Friday, July 29, 2011 2:36 PM
	To: geomoose-users at lists.sourceforge.net
	Subject: [Geomoose-users] caching and other ways to increase
performance
	I was wondering what anyone was doing, with regard to caching
tiles or other ways to boost performance in GeoMoose applications?
While our current applications are performing well in GeoMoose, we're
looking ahead as applications get more complex and bloated with data.
Has anyone done anything with GeoWebCache, for example, or some other
means?
	Got Input?  Slashdot Needs You.
	Take our quick survey online.  Come on, we don't ask for help
often.
	Plus, you'll get a chance to win $100 to spend on ThinkGeek.
	http://p.sf.net/sfu/slashdot-survey
	Geomoose-users mailing list
	Geomoose-users at lists.sourceforge.net
	https://lists.sourceforge.net/lists/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20110805/51542715/attachment.html
More information about the Geomoose-users mailing list
