[Geomoose-users] how to install geomoose?
Nitin Gadia nittyjee at gmail.com
Fri Aug 5 23:42:25 EDT 2011
oops...
got it working :)
I looked at the error log you mentioned, and it says that some file
was not found. I did it all over again, merging the files again, and I
checked that file, and it was there... then I installed it, and it's
working.
Great, thanks...
nitin
On Fri, Aug 5, 2011 at 4:43 PM, Eli Adam <EAdam at co.lincoln.or.us> wrote:
> Oh yeah, Bob make a good point below.  Old browser cache can be really
> annoying.  I think that ctrl+F5 on firefox clears it and reloads.
> Eli
>>>> On 8/5/2011 at 1:59 PM, in message
> <4E3C1357020000A80002CF77 at heckle>, "Bob
> Basques" <Bob.Basques at ci.stpaul.mn.us> wrote:
>> All,
>> Also make sure you aren't looking at some cached page in your
> browser.
>> You may want to reload after clearing your browser cache.
>> bobb
>>>> On 8/5/2011 at 1:19 PM, in message
> <4E3BEDB9.4F75.00CE.0 at co.lincoln.or.us>,
> "Eli Adam" <EAdam at co.lincoln.or.us> wrote:
>> Nitin,
>>> I installed "GeoMOOSE 2.4 for MS4W"
>>> and when I went to
>>> http://localhost/geomoose2/geomoose.html
>> Is this the address you get sent to from following the link at the
>> bottom of the main ms4w page found at http://localhost/ ?  Try using
> the
>> link at the bottom of the page of listed running applications.
>> HTH, Eli
>>> I got the same thing as the screenshot i provided
>>> nitin
>>> On Fri, Aug 5, 2011 at 1:41 PM, Eli Adam <EAdam at co.lincoln.or.us>
>> wrote:
>>>> Nitin,
>>>>      You will get something very similar to this,
>>>> http://geomoose.org/demo/geomoose2/geomoose.html
>>>> Eli
>>>>>>> On 8/5/2011 at 11:13 AM, in message
> <CAM3HAhQ7emOzhLp0863d+iuAG7wUmnUJxy2ZcmKQ=REPdwK1RQ at mail.gmail.com>,
>>>> Nitin
>>>> Gadia <nittyjee at gmail.com> wrote:
>>>>> If I install the "GeoMOOSE 2.4 for MS4W", what will I get on the
>>>>> screen? Would it be the same blank stuff without the tools or any
>>>>> basemaps?
>>>>> nitin
>>>>> On Fri, Aug 5, 2011 at 12:41 PM, Eli Adam
>>>> wrote:
>>>>>> Nitin,
>>>>>>> I went to
>>>>>>> and it worked...
>>>>>>> but I'm not getting the layers or the tools. Are those separate
>>>>>> adds?
>>>>>> The tools and layers should not be a separate add.  The web
>>>> mercator
>>>>>> demo is perhaps in need of a little attention to work as
>> intended.
>>>>>>> I thought that the "GeoMOOSE 2.4 for MS4W - Web Mercator Demo"
>>>>>>> would have the layers and tools already shown, like they are
>> here
>>>>>>> (without the edits):
> http://geomoose.org/demo/geomoose2-webmercator/geomoose.htmlhttp://geomooseo
>>>>>>> I've attached a screenshot to show what my screen is like.
>>>>>> I got similar results as you.
>>>>>>> Should I still install "GeoMOOSE 2.4 for MS4W" as you
>> recommended?
>>>>>> I think that is a good idea.  You will have to decide for
>> yourself.
>>>>>>> I would want to use the mercator demo if I can I think... I
>>>> probably
>>>>>>> want to be able to use the standard stuff right outside of the
>>>>>> box...
>>>>>> Once you are a little familiar with the working demo, then
>> perhaps
>>>> it
>>>>>> will be easier to look at the web mercator demo and make a few
>>>> tweaks to
>>>>>> make it work for you.  Perhaps search the email list about the
>> web
>>>>>> mercator demo, someone else may have already hit this and the
> fix
>> is
>>>> on
>>>>>> the list.
>>>>>>> After this is all done, I'll update the wiki :)
>>>>>> Thanks.
>>>>>> Eli
>>>>>>> thanks a lot
>>>>>>> nitin
>>>>>>> On Fri, Aug 5, 2011 at 11:36 AM, Eli Adam
>>>>>> wrote:
>>>>>>>> Nitin,
>>>>>>>>> I did get MS4W working, but not Geomoose at
>>>>>>>> http://localhost/geomoose/
>>>>>>>> Looks like gradual progress.
>>>>>>>> Does MS4W working means that you go to localhost and get the
>> MS4W
>>>>>> info
>>>>>>>> and details page?
>>>>>>>>> Here's what I did, in order:
>>>>>>>>> (1) Downloaded "ms4w_2.3.1.zip" from here:
>>>>>>>>> http://dl.maptools.org/dl/ms4w/
>>>>>>>>> (2) Already downloaded "GeoMOOSE 2.4 for MS4W - Web Mercator
>>>> Demo"
>>>>>>>> from here:
>>>>>>>>> http://geomoose.org/info/download.html
>>>>>>>>> (3) I transferred both of the *.zip files above to C:\
>>>>>>>>> (4) I unzipped each of them with winrar, and files with the
>> same
>>>>>>>> names
>>>>>>>>> as above were created as following:
>>>>>>>>> C:\GeoMOOSE-mercdemo-2.4-MS4W
>>>>>>>>> C:\ms4w_2.3.1
>>>>>>>> This unzipping step is where things seem to have gone wrong.
>>>>>> winrar
>>>>>>>> apparently defaults to creating a new folder and not merging
>>>>>> things.
>>>>>>>> Try the unzipping step again with a different program (like
> the
>>>>>> default
>>>>>>>> windows utility) or changing settings on winrar.  When you
>> unzip
>>>>>> both
>>>> those folders you should get C:\ms4w\(more here) and then the
>>>>>> geomoose
>>>>>>>> contents should get placed inside those folders like
>>>>>>>> C:\ms4w\apps\geomoose2\
>>>>>>>>> The files were separate.
>>>>>>>>> (5) I went to:
>>>>>>>>> C:\ms4w_2.3.1\ms4w\apache-install.bat
>>>>>>>>> And double-clicked.
>>>>>>>>> (6) I restarted the computer
>>>>>>>>> (7) I checked http://localhost/
>>>>>>>>> And I saw Mapserver
>>>>>>>>> (8) Since, the following file was separate:
>>>>>>>>> I "cut":
>>>>>>>>> C:\GeoMOOSE-mercdemo-2.4-MS4W\ms4w
>>>>>>>>> and "pasted" in:
>>>>>>>>> C:\
>>>>>>>>> and when it asked me to "merge", I clicked "yes"
>>>>>>>>> (9) I tried to go to:
>>>>>>>>> but got a "404 not found" message
>>>>>>>>> (10) I tried restarting the computer, and I went to:
>>>>>>>> This looks like a mistake on my part.  The apache alias seems
>> to
>>>> be
>>>>>>>> geomoose2 not geomoose.  However, just go to localhost and
>> scroll
>>>> to
>>>>>> the
>>>>>>>> bottom and it should show you how many application you have
>>>>>> installed
>>>>>>>> along with links to click on.  That will take you to
>>>>>>>> http://localhost/geomoose2/geomoose.html (this works partly
> for
>>>>>> me).
>>>>>>>> I'd recommend the other demo at
>>>>>>>> http://geomoose.org/downloads/GeoMOOSE-2.4-MS4W.zip  That is
>> the
>>>>>> one
>>>>>>>> that I tried when I first started and it seems to be the main
>>>> demo
>>>>>> and
>>>>>>>> work well.
>>>>>>>> HTH, Eli
>>>>>>>>> and it still didn't work
>>>>>>>>> (11) I tried to click:
>>>>>>>>> C:\ms4w_2.3.1\ms4w\apache-uninstall.bat
>>>>>>>>> then clicked
>>>>>>>>> and then tried again to go to http://localhost/geomoose/
>>>>>>>>> and it still didn't work.
>>>>>>>>> (12) I again tried restarting the computer, and again went
> to:
>>>>>>>>> I've done everything according to the instructions provided
>> me,
>>>>>>>>> however when I unzip the files, it is very different from
> what
>>>> the
>>>>>>>>> instructions say should happen, as detailed above. Unless you
>>>> know
>>>>>>>>> what is wrong clearly from what I wrote above, please try and
>> do
>>>>>> it
>>>>>>>>> yourself according to the instructions I've been provided,
> and
>>>>>> tell
>>>>>>>> me
>>>>>>>>> if I'm missing something.
>>>>>>>>> Thanks,
>>>>>>>>> Nitin
>>>>>>>>> On Thu, Aug 4, 2011 at 4:04 PM, Eli Adam
>>>>>>>> wrote:
>>>>>>>>>> Nitin,
>>>>>>>>>>> The directions have some serious problems:
>>>>>>>>>>> *First of all, the instructions at the wiki appear to be
>>>>>> identical
>>>>>>>> to
>>>>>>>>>> these
>>>>>>>>>>> instructions, which are WAY easier on the eyes, along with
>>>>>>>>>> screenshots:
>>>>>>>>>>> - Wiki:
> http://www.geomoose.org/wiki/index.php/Installation#Windows_Installation_Gui
>>>>>>>>>>> de
>>>>>>>>>>> - Identical better format:
>>>>>>>>>> http://www.geomoose.org/docs/install_ms4w.html
>>>>>>>>>> Thanks for fixing up the wiki formatting.  Yes, I think that
>> it
>>>>>> was
>>>>>>>>>> copied from one place to the other.
>>>>>>>>>>> *It says not to use "MS4W 3.0 beta 10 and GeoMOOSE, we
>>>> recommend
>>>>>>>> that
>>>>>>>>>> you
>>>>>>>>>>> use MS4W 2.3.1"
>>>>>>>>>>> - looking in the history here, it was upgraded from "beta
>> 10"
>>>> on
>>>>>>>>>> 4/20/10,
>>>>>>>>>>> and it is into "version 3.03" as of 7/12/11":
>>>>>>>>>>> http://www.maptools.org/ms4w/index.phtml?page=HISTORY.txt
>>>>>>>>>> MS4W 3.0.3 uses MapServer 6.x which GeoMoose is not quite
>> ready
>>>>>> for.
>>>>>>>>  I
>>>>>>>>>> think that Jim is currently updating that.  I would
> recommend
>>> MS4W
>>>>>>>>>> 2.3.1.  You can find it at, http://dl.maptools.org/dl/ms4w/
>>>>>>>>>>> *I download the following files:
>>>>>>>>>>> - MS4W: http://www.maptools.org/ms4w/
>>>>>>>>>>> - GeoMOOSE 2.4 for MS4W - Web Mercator Demo:
>>>>>>>>>>> *The files are different from what it explains in the
>>>>>> instructions.
>>>>>>>> I
>>>>>>>>>> ended
>>>>>>>>>>> up merging the folders that were in the geomoose folder
> with
>>>>>> what
>>>>>>>> was
>>>>>>>>>> in the
>>>>>>>>>>> MS4W folder, and when I typed in [http://localhost/]
> nothing
>>>>>>>> showed
>>>>>>>>>> up.
>>>>>>>>>> Both of these zip files are designed to be extracted at the
>>>> root
>>>>>> of
>>>>>>>> C:
>>>>>>>>>> (MS4W should be done first)  That will put a geomoose folder
>>>> into
>>>>>>>>>> C:\ms4w\apps\  It will also probably put a
>>>>>> httpd_geomoose_m24w.conf
>>>>>>>> in
>>>>>>>>>> C:\ms4w\httpd.d\ which sets up an Apache alias like this:
>>>>>>>>>> Alias /geomoose/ "/ms4w/apps/geomoose/htdocs/"
>>>>>>>>>> GeoMoose will be found at http://localhost/geomoose/ (or
>>>> whatever
>>>>>>>> your
>>>>>>>>>> .conf file sets up).  However, according to the
>>>>>> README_INSTALL.txt
>>>>>>>> at
>>>>>>>>>> C:\ms4w\, you should have gotten the main ms4w page at
>>>> localhost.
>>>>>>>> Try
>>>>>>>>>> making sure that you have gone through all the proper steps
>> to
>>>>>>>> install
>>>>>>>>>> ms4w.  The read me covers a lot of things, like have the MS
>>>>>>>>>> redistributables if needed, etc.  Specific errors and
> details
>>>> can
>>>>>>>> be
>>>>>>>>>> helpful for remote troubleshooting.  So does going to
>> localhost
>>>>>> give
>>>>>>>> an
>>>>>>>>>> error?  Is there anything in the apache logs?  In general,
>> MS4W
>>>>>> is
>>>>>>>> set
>>>>>>>>>> up to extract .zip files at the root of the drive and have
>>>>>>>> everything
>>>>>>>>>> working.  Searching the ms4w mailing list
>> http://osgeo-org.1803224.n2.nabble.com/ms4w-users-f4995553.html
>>>>>> may
>>>>>>>>>> help with particular errors or operating system details.
>>>>>>>>>> Best Regards, Eli
>>>>>>>>>>> What do I need to do??
>>>>>>>>>>> Nitin
>>>>>>>>>>> On Thu, Aug 4, 2011 at 10:12 AM, Bob Basques
>>>>>>>>>>> <Bob.Basques at ci.stpaul.mn.us>wrote:
>>>>>>>>>>>>  All,
>>>>>>>>>>>>  Ok, sorry about that I confused GM1.6 with GM2.6, for
> some
>>>>>>>> reason
>>>>>>>>>> they
>>>>>>>>>>>> looked the same to me.  Oops.
>>>>>>>>>>>>  I have installed GeoMoose 2.4 on a Windows 7 machine
>>>>>>>> successfully
>>>>>>>>>> with
>>>>>>>>>>>> OSGEO4W (similar to MS4W, but with a lot more stuff)  MS4W
>> is
>>>>>>>> also
>>>>>>>>>> supported
>>>>>>>>>>>> by the GeoMoose community, and is the preferred install
>>>> method
>>>>>>>> for
>>>>>>>>>> Windows,
>>>>>>>>>>>>  while I had to configure things manually for the OSGEO4W
>>>>>> version
>>>>>>>> of
>>>>>>>>>> things.
>>>>>>>>>>>>  I would stay away from OSGEO4W to begin with and stick
>> with
>>>>>> MS4W
>>>>>>>> in
>>>>>>>>>> the
>>>>>>>>>>>> near term.
>>>>>>>>>>>>  bobb
>>>>>>>>>>>> >>> Nitin Gadia <nittyjee at gmail.com> wrote:
>>>>>>>>>>>> ... looks like i didn't reply-all before either...
>>>>>>>>>>>> Earlier I asked Bob Basques whether I need a Windows
> Server
>>>>>>>> edition
>>>>>>>>>>>> installed, or I can just use what I have (windows 7
>>>> ultimate).
>>>>>>>>>>>> I suppose that Bob was implying that I can just install it
>>>> with
>>>>>>>> what
>>>>>>>>>> I
>>>>>>>>>>>> have.
>>>>>>>>>>>> thanks
>>>>>>>>>>>> nitin
>>>>>>>>>>>>   On Thu, Aug 4, 2011 at 9:24 AM, Nitin Gadia
>>>>>>>>>> wrote:
>>>>>>>>>>>>>  oops, i didn't reply-all
>>>>>>>>>>>>> Those instructions look easy enough.
>>>>>>>>>>>>> I'll try to do it today...
>>>>>>>>>>>>> in the meantime, what will I have if I am just going to
>>>>>> install
>>>>>>>>>> the
>>>>>>>>>>>>>>> GeoMOOSE 2.2 for MS4W”?
>>>>>>>>>>>>> Will I be able to see any basemaps?
>>>>>>>>>>>>> I suppose if I want ot see any basemaps I might just
>> install
>>>>>> the
>>>>>>>>>> “GeoMOOSE
>>>>>>>>>>>>> 2.2 for MS4W - Web Mercator Demo”?? Are there any
>>>> downsides
>>>>>> to
>>>>>>>>>> just
>>>>>>>>>>>>> installing the demo? Isn't web mercator a standard
> anyway?
>>>>>>>>>>>>> thanks a lot
>>>>>>>>>>>>> nitin
>>>>>>>>>>>>>   On Thu, Aug 4, 2011 at 7:03 AM, Dan Little
>>>>>>>> <danlittle at yahoo.com>
>>>>>>>>>> wrote:
>>>>>>>>>>>>>>   Yeah, referring to the .info website is not a good
> idea
>>>>>>>> anymore.
>>>>>>>>>> It
>>>>>>>>>>>>>> will probably expire at the end of this year.
>>>>>>>>>>>>>>    The old .info site only refers to 1.6 stuff and that
>> is
>>>>>> long
>>>>>>>>>> out of
>>>>>>>>>>>>>> anything resembling support.
>>>>>>>>>>>>>> *From:* Bob Basques <Bob.Basques at ci.stpaul.mn.us>
>>>>>>>>>>>>>> *To:* Nitin Gadia <nittyjee at gmail.com>;
>>>>>>>>>>>>>> geomoose-users at lists.sourceforge.net
>>>>>>>>>>>>>> *Sent:* Wednesday, August 3, 2011 4:37 PM
>>>>>>>>>>>>>> *Subject:* Re: [Geomoose-users] how to install geomoose?
>>>>>>>>>>>>>>    Nitin,
>>>>>>>>>>>>>>   Start here for a windows install:
> http://www.geomoose.info/moose1/index.php?option=com_content&task=view&id=12&It
>> e
>>>>>>>>>>> mid=30
>>>>>>>>>>>>>>   other OSs are here as well:
> http://www.geomoose.info/moose1/index.php?option=com_content&task=category&sec
>> t
>>>>>>>>>>> ionid=4&id=13&Itemid=30
>>>>>>>>>>>>>>   bobb
>>>>>>>>>>>>>> Hello,
>>>>>>>>>>>>>> I would like to install a server, and install geomoose
> on
>>>> it.
>>>>>>>>>>>>>> How do I do this??
>>>>>>>>>>>>>> I'm very new to doing this, so please bear with me.
>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>> Nitin
>>>>>>>>>>>>>> BlackBerry&reg; DevCon Americas, Oct. 18-20, San
>> Francisco,
>>>>>> CA
>>>>>>>>>>>>>> The must-attend event for mobile developers. Connect
> with
>>>>>>>>>> experts.
>>>>>>>>>>>>>> Get tools for creating Super Apps. See the latest
>>>>>> technologies.
>>>>>>>>>>>>>> Sessions, hands-on labs, demos & much more. Register
>> early
>>>>>>>>>> save!
>>>>>>>>>>>>>> http://p.sf.net/sfu/rim-blackberry-1
>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>> Geomoose-users mailing list
>>>>>>>>>>>>>> Geomoose-users at lists.sourceforge.net
>> https://lists.sourceforge.net/lists/listinfo/geomoose-users
>>>>>>>>> BlackBerry&reg; DevCon Americas, Oct. 18-20, San Francisco,
> CA
>>>>>>>>> The must-attend event for mobile developers. Connect with
>>>> experts.
>> technologies.
>>>>>>>>> Sessions, hands-on labs, demos & much more. Register early &
>>>> save!
>> sourceforge.net
>>>>> BlackBerry&reg; DevCon Americas, Oct. 18-20, San Francisco, CA
> experts.
>>>>> Get tools for creating Super Apps. See the latest technologies.
> save!
>>> The must-attend event for mobile developers. Connect with experts.
>>> Sessions, hands-on labs, demos & much more. Register early & save!
More information about the Geomoose-users mailing list
