[Geomoose-users] Identify Feture not working on layers
Brian Fischer bfischer at houstoneng.com
Wed Aug 10 22:26:01 EDT 2011
Is your projection of the shapefile the same as you setup in the mapbook.xml?
Brian Fischer, CFM
GIS Manager
Houston Engineering, Inc.
O 763.493.4522 | D 763.493.6664 | M 763.229.2734
-----Original Message-----
From: neslonotnilc [mailto:clinton at co.emery.ut.us]
Sent: Wednesday, August 10, 2011 2:45 PM
To: geomoose-users at lists.sourceforge.net
Subject: [Geomoose-users] Identify Feture not working on layers
I am doing an upgrade from a 1.x geomoose install.  I have my esri layers showing up in geomoose, but when I try to do an identify on the layers I only return the default X and Y coordinate template.  I have looked through the wiki, the online forum, and online searches and tried to make my data fit with what is presented but I still can't get identify to work.  Also a wierd thing that happens when I try to do a identify I get 1kb PNG files that populate the folder that contains the layer mapbook file.  Please point me in the right direction.  The identify tool is great for what we are trying to do with Geomoose, but if it is temperamental then maybe I should stick with the working 1.x install.  Only problem with that is some of the features don't work in the newer browsers.  Thanks.  Clinton
This is what I have in the mapbook.xml file:
<service name="identify" title="Identify" display="false"> <url>php/identify.php</url> <step type="spatial" name="shape" line="false" polygon="false"
jump-start="true" default="point">
<input type="visiblelayers" name="layers"/> </step> </service> __________
<tool name="identify" title="Identify" type="service" service="identify"/>
__________
In the layer mapbook I have:
LAYER
NAME			"PRECINCTS"
	DATA			"./PRECINCTS.shp"
	STATUS		DEFAULT
	TYPE			POLYGON
	TOLERANCE		3
	CLASSITEM		"NAME"
	LABELITEM		"NAME"
	CLASS
		EXPRESSION 'Orangeville #5.09'
		NAME	'Orangeville #5.09'
			STYLE
				COLOR 255 102 0
				OUTLINECOLOR 0 0 255
				SIZE 2
			END
	      LABEL
	        		TYPE TRUETYPE
	        		FONT vera_sans-bold
	        		SIZE 8
	        		ANTIALIAS true
	        		COLOR 153 0 153
	        		OUTLINECOLOR 254 254 254
	        		BUFFER 3
	        		MINFEATURESIZE auto
	        		PARTIALS FALSE
	        		POSITION ul
  	       END
	END
METADATA
	'identify_record' 'identify_precincts.html'
END
END
View this message in context: http://geomoose-users.964460.n3.nabble.com/Identify-Feture-not-working-on-layers-tp3243706p3243706.html
Sent from the Geomoose-users mailing list archive at Nabble.com.
uberSVN's rich system and user administration capabilities and model configuration take the hassle out of deploying and managing Subversion and the tools developers use with it. Learn more about uberSVN and get a free download at:  http://p.sf.net/sfu/wandisco-dev2dev
Geomoose-users at lists.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users mailing list
