[Geomoose-users] Identify Feture not working on layers
Clinton Olsen clinton at co.emery.ut.us
Thu Aug 11 10:58:22 EDT 2011
Dan Little,
Here are the contents of the identify tool using firebug and firefox.  I
hope this is what you wanted to look at.
<results><script/><html><![CDATA[<!-- MapServer Template -->
Detailed information for the area you clicked on the map...
<table border="0">
<tr>
<td colspan="2"><b><u>Ground Coordinates</u></b>
<br>
<b>X: </b>1751465
<br>
<b>Y: </b>6901114.5</td>
</tr>
<tr>
<td>&nbsp;</td>
<td>&nbsp;</td>
</tr>
</table>
<table border="0" cellpadding="1" cellspacing="2">
<tr>
<td colspan="2">Disclaimer: This information is being distributed as
demonstation data only.  You should not use the data for any other
purposes.</td>
</tr>
</table>
]]></html></results>
Brian Fischer,
The projection in my mapbook.xml is EPSG:2281.  The ESRI projection I am
using for the shape files is ESRI:102743.
Not sure what the EPSG equivalent is for that ESRI projection.  Maybe that
is why when I use the print feature it only prints a blank page.
-----Original Message-----
Sent: Wednesday, August 10, 2011 7:43 PM
To: neslonotnilc; geomoose-users at lists.sourceforge.net
Subject: Re: [Geomoose-users] Identify Feture not working on layers
Do you happen to have Firefox with Firebug installed?
I'd like to see the actual contents being sent back.  I'm not 100% sure
what's going wrong yet...
  _____
To: geomoose-users at lists.sourceforge.net
Sent: Wednesday, August 10, 2011 2:45 PM
Subject: [Geomoose-users] Identify Feture not working on layers
I am doing an upgrade from a 1.x geomoose install.  I have my esri layers
showing up in geomoose, but when I try to do an identify on the layers I
only return the default X and Y coordinate template.  I have looked through
the wiki, the online forum, and online searches and tried to make my data
fit with what is presented but I still can't get identify to work.  Also a
wierd thing that happens when I try to do a identify I get 1kb PNG files
that populate the folder that contains the layer mapbook file.  Please point
me in the right direction.  The identify tool is great for what we are
trying to do with Geomoose, but if it is temperamental then maybe I should
stick with the working 1.x install.  Only problem with that is some of the
features don't work in the newer browsers.  Thanks.  Clinton
This is what I have in the mapbook.xml file:
<service name="identify" title="Identify" display="false">
<url>php/identify.php</url>
<step type="spatial" name="shape" line="false" polygon="false"
jump-start="true" default="point">
<input type="visiblelayers" name="layers"/>
</step>
</service>
__________
<tool name="identify" title="Identify" type="service" service="identify"/>
__________
In the layer mapbook I have:
LAYER
NAME            "PRECINCTS"
    DATA            "./PRECINCTS.shp"
    STATUS        DEFAULT
    TYPE            POLYGON
    TOLERANCE        3
    CLASSITEM        "NAME"
    LABELITEM        "NAME"
    CLASS
        EXPRESSION 'Orangeville #5.09'
        NAME    'Orangeville #5.09'
            STYLE
                COLOR 255 102 0
                OUTLINECOLOR 0 0 255
                SIZE 2
            END
          LABEL
                    TYPE TRUETYPE
                    FONT vera_sans-bold
                    SIZE 8
                    ANTIALIAS true
                    COLOR 153 0 153
                    OUTLINECOLOR 254 254 254
                    BUFFER 3
                    MINFEATURESIZE auto
                    PARTIALS FALSE
                    POSITION ul
            END
    END
METADATA
    'identify_record' 'identify_precincts.html'
END
END
View this message in context:
http://geomoose-users.964460.n3.nabble.com/Identify-Feture-not-working-on-la
yers-tp3243706p3243706.html
Sent from the Geomoose-users mailing list archive at Nabble.com.
uberSVN's rich system and user administration capabilities and model
configuration take the hassle out of deploying and managing Subversion and
the tools developers use with it. Learn more about uberSVN and get a free
download at:  http://p.sf.net/sfu/wandisco-dev2dev
Geomoose-users at lists.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20110811/9a222d34/attachment.html
More information about the Geomoose-users mailing list
