[Geomoose-users] Identify Feture not working on layers
Dan Little danlittle at yahoo.com
Wed Aug 10 21:42:31 EDT 2011
Do you happen to have Firefox with Firebug installed?
I'd like to see the actual contents being sent back.  I'm not 100% sure what's going wrong yet...
>________________________________
>From: neslonotnilc <clinton at co.emery.ut.us>
>To: geomoose-users at lists.sourceforge.net
>Sent: Wednesday, August 10, 2011 2:45 PM
>Subject: [Geomoose-users] Identify Feture not working on layers
>Hi,
>I am doing an upgrade from a 1.x geomoose install.  I have my esri layers
>showing up in geomoose, but when I try to do an identify on the layers I
>only return the default X and Y coordinate template.  I have looked through
>the wiki, the online forum, and online searches and tried to make my data
>fit with what is presented but I still can't get identify to work.  Also a
>wierd thing that happens when I try to do a identify I get 1kb PNG files
>that populate the folder that contains the layer mapbook file.  Please point
>me in the right direction.  The identify tool is great for what we are
>trying to do with Geomoose, but if it is temperamental then maybe I should
>stick with the working 1.x install.  Only problem with that is some of the
>features don't work in the newer browsers.  Thanks.  Clinton
>This is what I have in the mapbook.xml file:
><service name="identify" title="Identify" display="false">
><url>php/identify.php</url>
><step type="spatial" name="shape" line="false" polygon="false"
>jump-start="true" default="point">
><input type="visiblelayers" name="layers"/>
></step>
></service>
>__________
><tool name="identify" title="Identify" type="service" service="identify"/>
>__________
>In the layer mapbook I have:
>LAYER
>NAME            "PRECINCTS"
>    DATA            "./PRECINCTS.shp"
>    STATUS        DEFAULT
>    TYPE            POLYGON
>    TOLERANCE        3
>    CLASSITEM        "NAME"
>    LABELITEM        "NAME"
>    CLASS
>        EXPRESSION 'Orangeville #5.09'
>        NAME    'Orangeville #5.09'
>            STYLE
>                COLOR 255 102 0
>                OUTLINECOLOR 0 0 255
>                SIZE 2
>            END
>          LABEL
>                    TYPE TRUETYPE
>                    FONT vera_sans-bold
>                    SIZE 8
>                    ANTIALIAS true
>                    COLOR 153 0 153
>                    OUTLINECOLOR 254 254 254
>                    BUFFER 3
>                    MINFEATURESIZE auto
>                    PARTIALS FALSE
>                    POSITION ul
>             END
>    END
>METADATA
>    'identify_record' 'identify_precincts.html'
>END
>END
>View this message in context: http://geomoose-users.964460.n3.nabble.com/Identify-Feture-not-working-on-layers-tp3243706p3243706.html
>Sent from the Geomoose-users mailing list archive at Nabble.com.
>uberSVN's rich system and user administration capabilities and model
>configuration take the hassle out of deploying and managing Subversion and
>the tools developers use with it. Learn more about uberSVN and get a free
>download at:  http://p.sf.net/sfu/wandisco-dev2dev
>_______________________________________________
>Geomoose-users at lists.sourceforge.net
>https://lists.sourceforge.net/lists/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20110810/c943f77e/attachment.html
More information about the Geomoose-users mailing list
