[Geomoose-users] Geomoose-users Digest, Vol 47, Issue 13
Dan Little danlittle at yahoo.com
Thu Aug 11 13:27:14 EDT 2011
Set the projection object at the map level to match the same projection as you've configured in the mapbook.
Are the precincts mapping properly?
>________________________________
>From: Clinton Olsen <clinton at co.emery.ut.us>
>To: geomoose-users at lists.sourceforge.net
>Sent: Thursday, August 11, 2011 11:03 AM
>Subject: Re: [Geomoose-users] Geomoose-users Digest, Vol 47, Issue 13
>Dan,
>I added projection to the mapfile, but I still get the same result. Below
>are the contents of the mapfile.  Thanks for your help so far.
>MAP
>NAME            'PRECINCTS'
>SIZE            800 650
>STATUS        ON
>EXTENT        1426801 6519737 2267577 7175357
>UNITS            FEET
>FONTSET        '../fonts/fontset.list'
>SYMBOLSET        '../symbols/symbol.sym'
>TRANSPARENT        TRUE
>IMAGETYPE        PNG
>QUERYMAP
>    STATUS    ON
>    STYLE        SELECTED
>END
>LEGEND
>    STATUS     ON
>END
>LAYER
>    NAME            "PRECINCTS"
>    DATA            "./PRECINCTS.shp"
>    STATUS        DEFAULT
>    TYPE            POLYGON
>    TOLERANCE        3
>    CLASSITEM        "NAME"
>    LABELITEM        "NAME"
>    PROJECTION
>            "init=esri:102743"
>    END
>    CLASS
>        EXPRESSION 'Orangeville #5.09'
>        NAME    'Orangeville #5.09'
>            STYLE
>                COLOR 255 102 0
>                OUTLINECOLOR 0 0 255
>                SIZE 2
>            END
>          LABEL
>                    TYPE TRUETYPE
>                    FONT vera_sans-bold
>                    SIZE 8
>                    ANTIALIAS true
>                    COLOR 153 0 153
>                    OUTLINECOLOR 254 254 254
>                    BUFFER 3
>                    MINFEATURESIZE auto
>                    PARTIALS FALSE
>                    POSITION ul
>             END
>    END
>    METADATA
>        'identify_record' 'identify_precincts.html'
>    END
>    TOLERANCE 0
>END
>END
>-----Original Message-----
>From: geomoose-users-request at lists.sourceforge.net
>[mailto:geomoose-users-request at lists.sourceforge.net]
>Sent: Thursday, August 11, 2011 9:22 AM
>Subject: Geomoose-users Digest, Vol 47, Issue 13
>Send Geomoose-users mailing list submissions to
>To subscribe or unsubscribe via the World Wide Web, visit
>    https://lists.sourceforge.net/lists/listinfo/geomoose-users
>or, via email, send a message with subject or body 'help' to
>You can reach the person managing the list at
>    geomoose-users-owner at lists.sourceforge.net
>When replying, please edit your Subject line so it is more specific than
>"Re: Contents of Geomoose-users digest..."
>Today's Topics:
>   1. Re: Identify Feture not working on layers (Dan Little)
>   2. Re: Identify Feture not working on layers (Clinton Olsen)
>Message: 1
>Date: Thu, 11 Aug 2011 08:15:13 -0700 (PDT)
>From: Dan Little <danlittle at yahoo.com>
>Subject: Re: [Geomoose-users] Identify Feture not working on layers
>To: Clinton Olsen <clinton at co.emery.ut.us>,    'Brian Fischer'
>    <bfischer at houstoneng.com>,
>"geomoose-users at lists.sourceforge.net"
>    <geomoose-users at lists.sourceforge.net>
>Message-ID:
>    <1313075713.13516.YahooMailNeo at web161212.mail.bf1.yahoo.com>
>Content-Type: text/plain; charset="iso-8859-1"
>I'm thinking you'll need to specify the projection in the layer entry.
>LAYER?
>?PROJECTION
>? ?'init=esri:102743'
>?END
>END
>>To: 'Dan Little' <danlittle at yahoo.com>; 'Brian Fischer'
>><bfischer at houstoneng.com>; geomoose-users at lists.sourceforge.net
>>Sent: Thursday, August 11, 2011 9:58 AM
>>Subject: RE: [Geomoose-users] Identify Feture not working on layers
>>Message
>>Dan Little,
>>Here are the contents of the identify tool using firebug and firefox.I hope
>this is what you wanted to look at.
>><results><script/><html><![CDATA[<!-- MapServer Template --> Detailed
>information for the area you clicked on the map... <table border="0"> <tr>
><td colspan="2"><b><u>Ground Coordinates</u></b> <br> <b>X: </b>1751465 <br>
><b>Y: </b>6901114.5</td> </tr> <tr> <td>&nbsp;</td> <td>&nbsp;</td> </tr>
></table> <table border="0" cellpadding="1" cellspacing="2"> <!-- MapServer
>Template --> <tr> <td colspan="2">Disclaimer: This information is being
>distributed as demonstation data only.  You shouldnot use the data for any
>other purposes.</td> </tr> </table> ]]></html></results>
>>Brian Fischer,
>>The projection in my mapbook.xml is EPSG:2281.  The ESRI projection I am
>using for the shape files is ESRI:102743.
>>Not sure what the EPSG equivalent is for that ESRI projection.  Maybe that
>is why when I use the print feature it only prints a blank page.
>>>From: Dan Little  [mailto:danlittle at yahoo.com]
>>>Sent: Wednesday, August 10, 2011 7:43  PM
>>>To: neslonotnilc;  geomoose-users at lists.sourceforge.net
>>>Do you happen to have Firefox with Firebug installed?
>>>I'd like to see the actual contents being sent back. ?I'm not  100%
>>>sure what's going wrong yet...
>>>> From: neslonotnilc  <clinton at co.emery.ut.us>
>>>>Sent: Wednesday, August 10, 2011 2:45  PM
>>>>Subject: [Geomoose-users] Identify Feture not working on  layers
>>>>Hi,
>>>>I am doing an upgrade from a 1.x geomoose
>    install.? I have my esri layers
>>>>showing up in geomoose, but when I
>    try to do an identify on the layers I
>>>>only return the default X and Y
>    coordinate template.? I have looked through
>>>>the wiki, the online
>    forum, and online searches and tried to make my data
>>>>fit with what is
>    presented but I still can't get identify to work.? Also a
>>>>wierd
>    thing that happens when I try to do a identify I get 1kb PNG files
>>>>that
>    populate the folder that contains the layer mapbook file.? Please
>    point
>>>>me in the right direction.? The identify tool is great for
>    what we are
>>>>trying to do with Geomoose, but if it is temperamental then
>    maybe I should
>>>>stick with the working 1.x install.? Only problem
>    with that is some of the
>>>>features don't work in the newer browsers.?
>    Thanks.? Clinton
>>>>This is what I have in the mapbook.xml
>    file:
>>>><service name="identify" title="Identify"
>    display="false">
>>>><url>php/identify.php</url>
>>>><step
>    type="spatial" name="shape" line="false"
>    polygon="false"
>>>>jump-start="true" default="point">
>>>><input
>    type="visiblelayers"
>    name="layers"/>
>>>></step>
>>>></service>
>>>>__________
>>>><tool
>    name="identify" title="Identify" type="service"
>    service="identify"/>
>>>>__________
>>>>In the layer mapbook I
>    have:
>>>>LAYER
>>>>NAME??? ???
>    ??? "PRECINCTS"???
>    DATA??? ??? ???
>    "./PRECINCTS.shp"
>>>>??? STATUS???
>    ??? DEFAULT
>>>>??? TYPE???
>    ??? ??? POLYGON
>    TOLERANCE??? ??? 3
>    CLASSITEM??? ??? "NAME"
>    LABELITEM??? ??? "NAME"
>>>>??? CLASS
>    ??? EXPRESSION 'Orangeville #5.09'
>    ??? NAME??? 'Orangeville
>    #5.09'
>    STYLE
>    ??? COLOR 255 102 0
>    ??? ??? OUTLINECOLOR 0 0
>    255
>    ??? SIZE 2
>    ??? END
>    LABEL
>    ??? TYPE TRUETYPE
>    ? ??? ??? FONT
>    vera_sans-bold
>    ??? ??? SIZE 8
>    ? ? ? ??? ??? ANTIALIAS
>    true
>    ??? COLOR 153 0 153
>    ? ? ??? ??? OUTLINECOLOR 254 254
>    254
>    ??? BUFFER 3
>    ? ??? ??? MINFEATURESIZE
>    auto
>    ??? PARTIALS FALSE
>    ? ??? ??? POSITION ul
>    ??? ? ? ? END
>    END
>>>>METADATA
>    'identify_record'
>>>>END
>>>>END
>>>>View this
>    message in context:
>http://geomoose-users.964460.n3.nabble.com/Identify-Feture-not-working-on-la
>yers-tp3243706p3243706.html
>>>>Sent
>    from the Geomoose-users mailing list archive at
>    Nabble.com.
>>>>uberSVN's
>    rich system and user administration capabilities and model
>>>>configuration
>    take the hassle out of deploying and managing Subversion and
>>>>the tools
>    developers use with it. Learn more about uberSVN and get a free
>>>>download
>    at:? http://p.sf.net/sfu/wandisco-dev2dev
>>>>_______________________________________________
>>>>Geomoose-users
>    mailing list
>>>>Geomoose-users at lists.sourceforge.net
>-------------- next part --------------
>An HTML attachment was scrubbed...
>Message: 2
>Date: Thu, 11 Aug 2011 08:58:22 -0600
>From: "Clinton Olsen" <clinton at co.emery.ut.us>
>To: "'Dan Little'" <danlittle at yahoo.com>,    "'Brian Fischer'"
>Message-ID: <A9F4EB55F8104D1783C7F34255ED1B6B at emery9e1eeaf61>
>Content-Type: text/plain; charset="us-ascii"
>Dan Little,
>Here are the contents of the identify tool using firebug and firefox.  I
>hope this is what you wanted to look at.
>Detailed information for the area you clicked on the map...
><table border="0">
><tr>
><br>
><b>X: </b>1751465
><br>
></tr>
><tr>
><td>&nbsp;</td>
><td>&nbsp;</td>
></tr>
></table>
><tr>
><td colspan="2">Disclaimer: This information is being distributed as
>demonstation data only.  You should not use the data for any other
>purposes.</td>
></tr>
></table>
>Brian Fischer,
>I'd like to see the actual contents being sent back.  I'm not 100% sure
>  _____
>Hi,
>I am doing an upgrade from a 1.x geomoose install.  I have my esri layers
>showing up in geomoose, but when I try to do an identify on the layers I
>only return the default X and Y coordinate template.  I have looked through
>the wiki, the online forum, and online searches and tried to make my data
>fit with what is presented but I still can't get identify to work.  Also a
>wierd thing that happens when I try to do a identify I get 1kb PNG files
>that populate the folder that contains the layer mapbook file.  Please point
>me in the right direction.  The identify tool is great for what we are
>trying to do with Geomoose, but if it is temperamental then maybe I should
>stick with the working 1.x install.  Only problem with that is some of the
>features don't work in the newer browsers.  Thanks.  Clinton
>This is what I have in the mapbook.xml file:
><service name="identify" title="Identify" display="false">
><url>php/identify.php</url> <step type="spatial" name="shape" line="false"
>polygon="false" jump-start="true" default="point"> <input
>type="visiblelayers" name="layers"/> </step> </service> __________
><tool name="identify" title="Identify" type="service" service="identify"/>
>__________
>In the layer mapbook I have:
>LAYER
>NAME            "PRECINCTS"
>    STATUS        DEFAULT
>    TYPE            POLYGON
>    TOLERANCE        3
>    CLASSITEM        "NAME"
>    LABELITEM        "NAME"
>    CLASS
>            STYLE
>                COLOR 255 102 0
>                SIZE 2
>            END
>          LABEL
>                    TYPE TRUETYPE
>                    FONT vera_sans-bold
>                    SIZE 8
>                    ANTIALIAS true
>                    COLOR 153 0 153
>                    BUFFER 3
>                    MINFEATURESIZE auto
>                    PARTIALS FALSE
>                    POSITION ul
>            END
>    END
>METADATA
>END
>END
>View this message in context:
>Sent from the Geomoose-users mailing list archive at Nabble.com.
>uberSVN's rich system and user administration capabilities and model
>configuration take the hassle out of deploying and managing Subversion and
>the tools developers use with it. Learn more about uberSVN and get a free
>download at:  http://p.sf.net/sfu/wandisco-dev2dev
>Geomoose-users mailing list Geomoose-users at lists.sourceforge.net
>Get a FREE DOWNLOAD! and learn more about uberSVN rich system,
>user administration capabilities and model configuration. Take
>the hassle out of deploying and managing Subversion and the
>End of Geomoose-users Digest, Vol 47, Issue 13
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20110811/14733361/attachment.html
More information about the Geomoose-users mailing list
